Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
SoCal: Corral Canyon Apr 22
Old Apr 20, 2006 | 07:33 PM
  #121
wifesaysimadumbass's Avatar
toyopnoy carveacre can be done with a total stocker just make sure your running boards are removed and we'll stick you in between two people with lockers
Old Apr 20, 2006 | 07:54 PM
  #122
ecchamberlin's Avatar
Wow! Lots of new faces on this one. So cool. Gettin kinda big also.
Well done Slayer of Lizards!
Old Apr 20, 2006 | 08:01 PM
  #123
Toyopnoy's Avatar
Sounds good, i've got the running boards, front spoiler and rear bumper pieces off. I ordered a rear bumper but I don't think it will be in on time so i'll run it with just the steel bracket pieces sticking out. Sounds like fun...!!!
Old Apr 20, 2006 | 08:04 PM
  #124
deathrunner's Avatar
damn i'm missing out,
i need more email addresses..... I will be the email king and send out emails when new runs are posted.
I like big groups of yotas, we are quicker than big groups of heeps. No offense matt.
Old Apr 20, 2006 | 08:07 PM
  #125
Marc P's Avatar
This will be a good run. Carveacre is always a good time.
Makenna and I will try to make breakfast too.
After looking at my front suspension today I think we should do an episode of "Overhaulin" Yotatech style, and SAS Rover!!!
Old Apr 20, 2006 | 08:37 PM
  #126
Marc have you had a chance to see if you damaged the torsion bar in front?
BTW if you do SAS rover I would gladly be up for helping out. Not that I would have a clue what to do.
Old Apr 20, 2006 | 08:40 PM
  #127
Marc P's Avatar
Damage is to the upper control arm on drivers side--bushing is destroyed, the bolt that is supposed to be centered is resting on the bottom..pushing the contol arm up and causing the lean.
I have ordered the Energy Suspension bushing kit, but it is a big job.
Old Apr 20, 2006 | 08:44 PM
  #128
I have been hearing some funny sounds from my front lately alsoa nd think it is time for some new upper and lower a-arm bushings here also. Not so sure I want to to Poly though. Yes they are stiff and really strong but they squeek like crazy. Have you heard Bruce's? Yes rubber is an inferior material but it is quiet and if it will last for 5 years....
Your thoughts?
Old Apr 20, 2006 | 08:55 PM
  #129
Beerdrinker's Avatar
man I praying to the computer gods that the server upgrades go well! frickin working fri night and all day sat suck big time, If all goes well I'll see you guys at the breakfast spot. oh if I drive a little too agressive it's only because i got to relieve all this pressure on me.
Seth if i give you my email you got to promise not to sell it to your protologist ha!
I had funny clunky, metal shifting kinda sounds comming from my frt end last year, ended up being loose lower control arm bolts, just starting to hear it again.
Old Apr 20, 2006 | 09:00 PM
  #130
Marc P's Avatar
Not sure what I am going to do. I ordered the Energy stuff because I get it cheap through work, but I dont want to put a bunch of money into it because at some point it will all be cut off.
Old Apr 20, 2006 | 09:02 PM
  #131
Tanto's Avatar
SAS? On Rover? I'll help. Just lemme know what food I'll be picking up
Old Apr 20, 2006 | 09:08 PM
  #132
AHA Marc you have finally decide to accept what i named your truck!!!!!!!!!!!!!!!! i love it you know you can't resist the dark side.... it is your destiny..... you guys and your funny sounds.... Upgrade your stereo....... and wait till something breaks. i think i noticed a crack in one of the main leafs in my front spring pack..... (probably from the unintended 3 foot jump at superstition).... but unless the whole pack breaks it's just one leaf beside i can only see a kinda crack on one side it does'nt seem to go all the way through the leaf
Old Apr 20, 2006 | 09:30 PM
  #133
Sleeper's Avatar
Originally Posted by Marc P
......at some point it will all be cut off.
My cutting torch should do the trick! Let me know when and where. Between that and about 20 grinding wheels that IFS will drop like a rock.
Old Apr 20, 2006 | 09:31 PM
  #134
Tanto's Avatar
Old Apr 20, 2006 | 09:34 PM
  #135
Snorkeldepth's Avatar
This job is in my destiny. Where'd you get the kit? I've been dreading this after hearing that I'll need to find a multi ton press for the bushings. One of these days I'll actually get out with you guys.
Old Apr 20, 2006 | 09:36 PM
  #136
AH64ID's Avatar
I have one for sale, not activly. Its a urethane one, with red bushings.... I wont be home for 10 days...
Old Apr 20, 2006 | 09:44 PM
  #137
Sleeper's Avatar
Originally Posted by Tanto
Andy - just left you a message on your voicemail
Just got the message. I'll bring them to the run. I just tested them with my 3/4" greasable bolts and they fit like a glove. We can switch out your OEM's at some point. Sounds like a wrenching party to me.
Old Apr 20, 2006 | 10:12 PM
  #138
Tanto's Avatar
It could be done at my apartment parking space next to the BMW and the Porshe
Old Apr 21, 2006 | 07:03 AM
  #139
Big Job is an understatement. Way back when I went to have that done. You have to retain the metal sleev around the stock rubber bushing. They don't sell new ones and it is necessary. They vulcanized the rubber on to that sleeze so you have to burn them off (P.I.T.A.) If you try to pry them your just gonna screw em up. At least that is what Protrux told me. If you want, I can see if they have a set of factory upper arms, might be easier just to swap in some new stockers with good bushings.
Old Apr 21, 2006 | 07:21 AM
  #140
Oh yeah, the official "SoCal Yotatech Event List" is in effect.
https://www.yotatech.com/forums/show...652#post881652
