Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
28th Annual Hump N Bump - Las Vegas
Old Aug 17, 2008 | 05:28 PM
SinCityFJC's Avatar
The 28th Annual Hump N Bump will take place
November 7th and 8th 2008.
28th Annual Hump n Bump
We have reserved the County Fair grounds for camping
it has power / water and lots of room for all the RV`s
The Trails!
The follow trails will be ran this year:
Arockalpse - Extreme trail with a gigantic boulder at the beginning. This trail is rated 4 and should not be attempted unless you have 35"+ tires, 2 lockers and do not care what you vehicle looks like!
Bowl Trail - Perfect trail for those with stock to lightly modified vehicles. The trail winds through the desert through some very scenic parts of the Logandale area. There are a few obsitcles for those of you adventurous types but all are optional. At the very end of the run you can really test your driving skills and attempt the S-TURN. Though it is optional we suggest lockers front and rear and there is a possibility for some body damage. Full size not recommended in the S-Turn and are guaranteed body damage.
Bronco Falls - A trail named after the one biggest obsticles in the trail, a huge vertical climb up a rock wall. Though it looks more intimidating then it is difficult a good set of tires and some low gears will get you to the top.
Hawkins Trail - Scenic trail that takes you through the mountains to the valley adjacent to the Logandale Valley. This is the connector trail for many other trails such as Matterhorn, Arockalypse and The Bowl trail. So if your looking for a scenic easier trail take the Hawkins Trail.
Matterhorn - Rated probubly a 2 this trail is good for those slightly modified vehicles. Scenic ride through the Logandale hills to some mild obsticles. Great optional off camber climb just before a large climb that puts you back in the launch postition.
Rock Bottom - This is a great trail for those looking for a challenge. Rated a 3+ this trail will test your rig. The entrance to the trail is a V notch that you tip toe through. From there you crawl some sand stone obsticles along the way until you end up in a canyon with 4 ways out. The easiest is rated a 2 or 3 the hardest put mosts on there roof! As the trail comes to an end you have two ways to exit the trail: the S turn near the end of the trail where your powersteering, gearing and brake control abilities get a major workout or the waterfall which is pretty steep flat rock wall decent. After the trail have some fun at the sand dunes and back to base camp. Trail will take about half the day with a large group so bring snacks and plenty of water.
ter Trail - This trail will challenge the stock the vehicle but still have excitement for those modified rigs with some optional obsticles. This trail is also close to base camp and is famous for unofficial night runs. Rated about a 2-3 depending on the optional obstacles.
We have scenic runs planned for those who want to enjoy the desert.
Bitter Springs and The Logandale Loop.
Please note:
The Country Fair Grounds have 110 power / water / restrooms
to use this facility we need to add a RV fee.
A $20.00 RV fee
Please Note*
No Fee for tent camping on the grass
No Parking on the grass
There is an area wide enough next to the grass and RV`s
that will be reserved for tent camping.
** ARE YOU READY TO REGISTER? **
Register Online
*Microsoft Internet Exp must be used to fill out the form online.* :yawinkle:
Old Aug 17, 2008 | 05:32 PM
SinCityFJC's Avatar
There was even a FJ Cruiser at last years Hump N Bump & press coverage http://www.4wdandsportutility.com/ad...ide/index.html
Hump N Bump media coverage from years past
2004/24th Four Wheeler http://www.fourwheeler.com/eventcove...ump/index.html
2005/25th? Off-Road Magazine Land Rover Disco feature @ Hump N Bump http://www.off-roadweb.com/features/...ver/index.html
2006/26th JP Magazine http://www.jpmagazine.com/eventcover...ing/index.html
Pics My MudPro @ written by Mo
2006/26th J Rations http://rides.webshots.com/album/556474363PGHNMJ http://store.jrations.com/product_in...2b041c142d68fb
2007/27th 4WD & Sport Utility http://www.4wdandsportutility.com/ad...ide/index.html
Old Aug 17, 2008 | 06:10 PM
SinCityFJC's Avatar
Pics from Hump N Bump & Logandale Trails System
This thread needs some pics with Toyotas playing on the scenic trails for Hump N Bump
My FJC - Bowl Trail
Don & Tammy- Bowl Trail
Matterhorn Trail
Exit from Upper Rock Bottom to the Dunes
More Logandale pics
Redeth005
Jun 28, 2018 08:16 PM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
83
Sep 27, 2015 04:13 PM
metalhed
Sep 8, 2015 10:54 AM
