Buying & Selling Advice - Feeler/Gauging Interest This general forum is for those seeking information about buying, model features/differences, pricing to sell, and related advice
Looking at a 92 Toyota Pickup, what to check for.
Old Mar 7, 2012 | 07:41 PM
bleach's Avatar
1992 Toyota Pickup 4x4 V6, manual.
I maybe trading my 1996 VW Golf GTI VR6, for this pickup. What are common faults with the truck, what fails often.
Owner's AD:
"92 toyota pickup, great truck, starts every time. brand new winter tires. ($700) also still have the summers. roll bars are not on, will come with the truck though. only problem is e brake is broken. standard 4x4. 297000 km"
Old Mar 7, 2012 | 07:54 PM
Diablo22RE's Avatar
Standard transmission with no e-brake, thats got to be tough on the transmission. Listen for ANY grinding in the transmission (in any gear). Make sure both hubs lock and the 4x4 hi/lo works. That's about all i can think of right now. Maybe check to see if A/C works.
Does it have the 4 or 6 cylinder?
Also, welcome to YT!
Old Mar 7, 2012 | 07:55 PM
Stuwy123's Avatar
Run the VIN and see if the mileage is within range.
Pass the VIN to toyota as see if the timing belt has been changed recently.
Look for the standard used vehicle stuff, rusted frame, busted shocks/springs,
Looks like the back-end is sagging pretty good.
A replaced fender is a good indicator of a fender bender, look for a crumpled inner fender and other damage.
Old Mar 7, 2012 | 07:56 PM
Stuwy123's Avatar
No e-brake is not a deal breaker, a new cable is ~$120 from NAPA or anywhere else.
Old Mar 7, 2012 | 08:08 PM
ksti's Avatar
Is that the lighting or is the front clip a different color?
Old Mar 7, 2012 | 08:11 PM
whelan709's Avatar
rust, on the rear of the frame where the exhaust hangers are welded. That whole bar can rust through. rust on the cab corners or rockers. or on the frame near the leaf mounts.
Check for high idle, or fluctuating idle!
some problems i had!
x2 on the timing chain, and maybe check if the head gasket was done too!
Old Mar 7, 2012 | 08:24 PM
bleach's Avatar
V6, Thank you. How do I tell if the hubs lock and the 4x4 works? (sorry truck newb, here. )
Good points, both fenders have been replaced.
Nope, the truck is grey the fenders are black.
thanks. Do the HG fail often in this motor? how are cost of motor parts. (Belts, chains, water pumps, seals, ETC.)
on my car the water pump is $50 and $120 respectably. (Main and AUX.)
maintenance parts are cheap, can the same be said for this truck?
Old Mar 7, 2012 | 09:12 PM
California's Avatar
Click and read. This is basically the best response ever given to the question you're asking. Tells you about all the systems and typical fail points.
http://www.toyotanation.com/forum/80...what-look.html
The head gaskets have been a particularly notable fail point for the v6 motor.
Kelby
Old Mar 7, 2012 | 09:50 PM
Diablo22RE's Avatar
Originally Posted by bleach
V6, Thank you. How do I tell if the hubs lock and the 4x4 works? (sorry truck newb, here. )?
If it has manual hubs, just turn them until they are in the locked position. It's like a little dial.
It's not a big deal if they don't turn, it just means you'll have to rebuild them. If they do turn, see if you can take it to a dirt road and pop it in $4x4. If it doesn't have a dial like this on the front wheels, it probably has automatic disengaging differential (or A.D.D). More importantly check the frame to make sure it's clean.
Old Mar 7, 2012 | 11:37 PM
Stuwy123's Avatar
Put it in 4wd, the 4wd light on the dash should light up.
Try 4Lo as well.
Old Mar 7, 2012 | 11:44 PM
wyoming9's Avatar
Red face
I doubt the e-brake working is as simple as a cable if it is has not worked in a while by now the bell cranks are seized in the brackets.
Then while you have it all apart may as well replace the rear brakes.
Looking at a new vehicle take it for a ride see how it drives in general. does it shake above 25 mph does it pull left or right
Strange wear patterns on the tires.
4 high and low both work and both the transfer case and transmission shift smooth.
ask why the different colored fenders.
The overall condition under the hood while it does not need to be squeaky clean look for hacked wiring fluid leaks.
Mice and squirrel nests
just look for things that look out of place and wrong.
Take a friend along to keep telling you your crazy to buy this truck and keep picking out the little imperfections .
Good luck
Old Mar 9, 2012 | 04:07 PM
bleach's Avatar
Holy, rust bucket!!! One side looks very good, the other not so much.
The box is shot. No way, will i trade my car for it.
Thank you, everyone for all the advice. I will keep looking.
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
94hiluxZE
Jun 22, 2015 10:42 AM
paxanders
Jun 21, 2015 06:29 AM
