Got the CB installed
I don't have the antenna mount yet, I will order it from All Pro Off Road
tomorrow.
Co-Founder/Administrator
That is a nice radio.
http://www.www.premiere-electronics....laxydx95t.html
I take it does CB too.
Is it easy to hit the 40 channels, or do you have to manually tune them?
Also does it put out more power too when on the CB channels, or does it cut back to 4 or 5 watts?
Yes it has 11 meter CB also with the same power as the 10 meter, change channels like your cb's. Has upper and lower side band. Dead keys 50 and
swings little over 200. Adjustable power, has frequency counter also. Top
and bottom heat sinks.
Predator 10K double coil, it can handle 10,000 Watts +
http://www.1stopelectronics.com/
The guy that ownes this shop knows his CB and Export radio's. His name is Frank, and
if your interested in a export, he can tune it and set it up for 11 meter [cb channels]
and it will be right when you get it. this is where I bought mine. Just tell him you been
talking too HogMan about an export, he will shoot you straight.
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
