FJ Cruiser 2007 & on
10k
Old 05-31-2007, 07:48 PM
ISurfer88's Avatar
10k
comin up on 10K, any recommended maintainance that should be done?
Old 05-31-2007, 10:10 PM
AxleIke's Avatar
If you haven't changed the oil yet, probably a good time
Rotate tires, again, if you haven't already done so.
I usually change the diff/xfer/tranny fluid at 20k, but if you want, you could do it now.
Old 06-01-2007, 05:26 AM
Co-Founder/Administrator
Staff
Corey's Avatar
Should be in the owners manual or the other maintenance pouch that came with the rig.
Propeller shafts will need greasing, but I have them do mine every 3K when I take it in for the oil change anyways.
Check the in cabin air filter to see how dirty it is, good time to get new wipers too if you still have the original ones.
I will have to check into this too, as my next oil change is due at 10K (almost 8K here), and I will get the required 10K check performed.
Old 06-01-2007, 05:51 AM
Staff
Corey's Avatar
A little update, I dug out the maintenance pouch, and it had info to get this online:
1. Head to Toyotas website
http://www.toyota.com/
2. Select Owners from the top link.
3. Then select Scheduled Maintenace.
4. This will bring up a new window where you input the info and mileage of your rig.
This is what you will see for 10K.
http://smg.toyotapartsandservice.com...=2007&int_id=2
Replace engine oil and oil filter 1
Rotate tires
Visually inspect brake linings/drums and brake pads/discs
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Lubricate propeller shaft (4WD only)
Re-torque propeller shaft bolt
Tighten nuts and bolts on chassis
Driving on Salted Roads
Driving Off-Road, on Dirt Roads or on Dusty Roads
Inspect ball joints and dust covers
Inspect drive shaft boots (4WD only)
Inspect engine air filter
Inspect steering linkage and boots
In Addition to Above, Daily Maintenance When Driving Off-Road Through Deep Sand, Mud or Water
Check ball joints and dust covers
Check brake lines and hoses
Check brake pads/discs
Check differential oil
Check drive shaft boots
Check engine air filter
Check nuts and bolts on chassis
Check steering linkage and boots
Check transfer case oil (4WD models)
Check transmission fluid or oil
Lubricate propeller shaft (4WD models)
Applicable Footnotes:
1) Reset the oil replacement reminder ("MAINT REQD") light after replacing engine oil.
You have the option at the above link to print out the list too.
There is also another button on that page you can push called Maintenance Definitions which will bring up this info.
2007 FJ Cruiser
10,000 Miles - 12 Months
Active Height Control System
Inspect the lines, accumulators and pump and replace the system fluid when specified. For recommended fluid, refer to your Owner's Manual.
Automatic Transmission Fluid or Manual Transmission Oil
Inspect or replace at specified intervals. When performing inspections, check each component for signs of leakage. If you discover any leakage, have it repaired by a qualified technician immediately.
Ball Joints and Dust Covers
Check the suspension and steering linkage ball joints for looseness and damage. Check all dust covers for deterioration and damage. Replace any deteriorated or damaged parts. A qualified technician should perform these operations.
Brake Lines and Hoses
Visually inspect for proper installation. Check for chafing, cracks, deterioration and signs of leakage. Replace any deteriorated or damaged parts. A qualified technician should perform these operations.
Brake Linings/Drums and Brake Pads/Discs
Check the brake linings (shoes) and drums for scoring, burning, fluid leakage, broken parts and excessive wear. Check the pads for excessive wear and the discs for runout, excessive wear and fluid leakage. Replace any deteriorated or damaged parts. A qualified technician should perform these operations.
Cabin Air Filter
Replace at specified intervals. Driving in heavy traffic, on dirt roads or in urban, desert or dusty areas may shorten filter's life. More frequent replacement may be necessary.
Charcoal Canister (CA, MA and NY Vehicles)
Check for internal damage and clogging. If necessary, clean with compressed air or replace. A qualified technician should perform these operations.
Differential Oil
Replace at specified intervals. When performing inspections, check each component for signs of leakage. If you discover any leakage, have it repaired by a qualified technician immediately.
Drive Belts
Inspect for cracks, excessive wear and oiliness. Check the belt tension and adjust if necessary. Replace the belts if they are damaged.
Drive Shaft Boots
Check the drive shaft boots and clamps for cracks, deterioration and damage. Replace any deteriorated or damaged parts and, if necessary, repack the grease. Selected models also require periodic inspection of the driveshaft bolt for proper torque. A qualified technician should perform these operations.
Engine Air Filter
Replace at specified intervals. When performing inspections, check for damage, excessive wear and oiliness, and replace if necessary.
Engine Coolant
Drain and flush the cooling system and refill with ethylene-glycol type coolant. Inspect hoses and connections for corrosion and leaks. Tighten connections and replace parts as necessary. A qualified technician should perform these operations. (For futher details, refer to 'Radiator, Condenser and Hoses' in the 'Vehicle Maintenance and Care' section of the Owner's Manual.) Note: Your Toyota is equipped with Genuine Toyota Super Long-Life Coolant. The replacement intervals for engine coolant recommended in this booklet are based on replacement with Genuine Toyota Super Long-Life Coolant or similar high-quality non-silicate, non-amine, non-borate ethylene-glycol coolant with long-life hybrid organic acid technology (i.e. a combination of low phosphates and organic acid). If another type of ethylene-glycol coolant is used, replacement intervals may be different.
Engine Oil and Filter
Replace the oil filter and drain and refill the engine oil at specified intervals. For recommended oil grade and viscosity, refer to the Owner's Manual.
Engine Valve Clearance
Inspect for tappet noise and engine vibration and adjust if necessary. A qualified technician should perform this operation.
Exhaust Pipes and Mountings
Visually inspect the exhaust pipes, muffler and hangers for cracks, deterioration and damage. Start the engine and listen carefully for any exhaust gas leakage. Tighten connections or replace parts as necessary.
Fuel Lines and Connections, Fuel Tank Band and Fuel Tank Vapor Vent System Hoses
Visually inspect for corrosion, damage, cracks and loose or leaking connections. Tighten connections or replace parts as necessary.
Fuel Tank Cap Gasket
Visually inspect for cracks, deterioration and damage and replace if necessary.
Nuts and Bolts on Chassis and body
Retighten the seat-mounting bolts and front/rear suspension member retaining bolts to specified torque.
Propeller Shaft
Lubricate the propeller shaft spiders and slide yokes with lithium-base chassis grease and the double cardan joint with molybdenum-disulfide lithium-base chassis grease. Only a qualified technician should re-torque the bolt.
Radiator Core and Condenser
Inspect for debris and signs of damage. Have any problem repaired immediately by a qualified technician.
Spark Plugs
Replace at specified intervals. Install new plugs of the same type as originally equipped. A qualified technician should perform this operation. To obtain optimum enginge performance on Camry with 2GR-FE, RAV4 with 2GR-FE and Avalon, it is imperative to use Denso FK20HR11 plugs or equivalent.
Steering Gear Box
Inspect for signs of leakage. If you discover any leakage, have it repaired immediately by a qualified technician.
Steering Linkage and Boots
With the vehicle stopped, check for excessive freeplay in the steering wheel. Inspect the linkage for bending and damage and the dust boots for deterioration, cracks and damage. Replace any damaged parts. A qualified technician should perform these operations.
Timing Belt
Replace every 90,000 miles. A qualified technician should perform this operation.
Tire Rotation
Tires should be rotated at specified intervals according to the instructions in the Owner's Manual. When rotating tires, check for damage and uneven wear. Replace if necessary.
Transfer Case Oil
Inspect or replace at specified intervals. When performing inspections, check for signs of leakage. If you discover any leakage, have it repaired by a qualified technician immediately.
Wheel Bearing and Drive Shaft Bushing Grease
Repack the wheel bearings with wheel bearing grease and the drive shaft bushing with molybdenum-disulfide lithium-base chassis grease. A qualified technician should perform these operations.
Old 06-01-2007, 09:18 AM
ISurfer88's Avatar
tnx, that toyota site has it all, very cool. im going to print out a copy and show it to them when i go in to make shure they "remember" to do all these things
AudiKev
09-03-2019 02:55 PM
dumpster84
04-30-2016 06:03 AM
alimant100
01-20-2016 05:58 PM
noahstancik
09-10-2015 10:47 AM
Quick Reply: 10k
