93-98 T100s All T100 trucks
Wheel Fitment and Backspace
Old Oct 13, 2009 | 09:16 PM
Kirbyt100's Avatar
Hey guys I was wondering what's the best backspace to go with the T... I'm going with a 15/8 Pro Comp Rock Crawlers but I have no clue with the backspace... Im currently riding on stock wheels with bfg all terrains 32/11.5/15's! I want it to be poking out a bit also... Please can someone post some pics of how it would look.Thanks
Old Oct 14, 2009 | 08:00 AM
4Crawler's Avatar
You can easily measure the back spacing on the wheels you have and go from there:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
And how does back spacing and wheel width affect track width?
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
Old Oct 14, 2009 | 09:10 AM
tj884Rdlx's Avatar
11.5s will stick out on either backspace available. the lower the number, the farther they will stick out. i went with 3.5 on my 15x8s and with 10.5" skins they just come outside the fender well. you'll have another inch of rubber.
bear in mind when turning full lock you may rub the outer edge of the tire if you don't have some lift
Old Oct 14, 2009 | 01:52 PM
Kirbyt100's Avatar
so whats the best backspace for me without me rubbing
Old Oct 14, 2009 | 02:01 PM
4Crawler's Avatar
The closer the backspacing is to stock the less likely the tires are to rub. Why? The closer the wheels/tires are to the body, the smaller the arc they sweep out while steering and it is when that arc of the tire intersects the arch of the wheel well that you have rubbing:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Oct 15, 2009 | 01:06 PM
tj884Rdlx's Avatar
well, the catch with that width tire is without some lift, you may rub regardless of back space.
if you have a smaller backspace, like 3.5", you move the wheel out, and can rub the outer edge of the tire. with a 4.25" backspace, you risk rubbing the inside edge of the tire. it depends on your lift, if any, and the actual size of the tire, which varies by manufacturer regardless of the size they "name" it.
do you have any lift at all?
Old Oct 15, 2009 | 05:18 PM
Matt3203's Avatar
this is a t100 here not a pickup
t100s can fit 33s with tbar crank
Old Oct 15, 2009 | 05:41 PM
Kirbyt100's Avatar
No lift... stock rims... BFG ALL T.
Old Oct 15, 2009 | 05:43 PM
Kirbyt100's Avatar
so im thinking of purchasing the cragar soft 8's 15/8 4 inch backspacing...
Old Oct 17, 2009 | 10:09 PM
tj884Rdlx's Avatar
aw jeez, my bad. i did not see T100. if you do go with soft 8's, i can recommend summit racing for price. i got mine there for $40 each i believe. i was able to pick them up at the local store though.
Old Nov 11, 2009 | 07:02 PM
93yotaSR5's Avatar
I have 31x10.5x15. Should I get 4 or 3.75 in back spacing? I have a 4crawler 1" body lift on the way.
Old Nov 11, 2009 | 07:05 PM
4Crawler's Avatar
Either will work, stock is around 4.75" so your tires will be sticking out wider than they do now.
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
