93-98 T100s All T100 trucks
Rearend noises
Old Mar 3, 2006 | 06:14 PM
RETRO's Avatar
Rearend noises
I have a 1995 4x4 T-100..I haer a vibration noise in the rearend but when I let off the gas it stops..I changed the rear gear oil it was fine no metal..I am thinking it is the hanger bearing or ujoints..I don't feel the vibration but trather hear it(if that makes sense)..
Old Mar 7, 2006 | 08:55 AM
Tato97T100's Avatar
I would definately check the rear u-joint..it sounds like the culprit since you said it stops once you let off the gas pedal.
either way let us know... you'll be lucky if its the u-joints if you can replace them yourself.
Old Mar 12, 2006 | 12:57 PM
RETRO's Avatar
Thanks..This forum doesn't get alot of posting
Old Mar 12, 2006 | 01:12 PM
wjwerdna's Avatar
hmm, just saw this, I had a dodge dakota, did the same before I got rid of it, I was told it was the bearings in the rear axle...
Old Mar 12, 2006 | 01:13 PM
wjwerdna's Avatar
I had changed the oil too, and saw nothing
Old Mar 13, 2006 | 06:27 PM
Tato97T100's Avatar
You're very right...its disapointing how few posting happen here for t100's.
Where is everybody?!
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
