Rearend noises
Rearend noises
I have a 1995 4x4 T-100..I haer a vibration noise in the rearend but when I let off the gas it stops..I changed the rear gear oil it was fine no metal..I am thinking it is the hanger bearing or ujoints..I don't feel the vibration but trather hear it(if that makes sense)..
I would definately check the rear u-joint..it sounds like the culprit since you said it stops once you let off the gas pedal.
either way let us know... you'll be lucky if its the u-joints if you can replace them yourself.
zytra
Jan 24, 2019 03:16 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
