Rear Shock Mounts
Rear Shock Mounts
I just replaced all the shocks on my 97 T100 and got to the last one on the rear driver side. The top mount bolt came out fine and the lower one sheared off leaving the shaft stuck in the mount. Tried welding a nut to it to get it out with no luck. Anyone know what the bracket is called that the bolt threads into? I’m not sure if it’s an orderable part of if I’ll have to try and find it at a junk yard. Any info would be great.
You could also as an alternative drill it out and re tap the hole with a special bit. Very easy I had to do it once.
highonpottery
Nov 29, 2011 12:38 PM
