My 97 T100 Build Big and Low!
#84
Counld not get a good shot under the truck, too much black. This should give you a good idea. Had to fold the pinch weld up to get the sliders tucked up .
Plates for frame are 1/4 inch, steel shop had them left over, legs are 1x3 and main bar is 2x4.
#91
Got the bug to get the new shoes on.
Had to make the sliders shorter, gonna need to trim the body mounts as well.
#95
Just put some paint on it to keep the rust away. Will finish the cut to the bumper as I build a new one. Took 1 inch in a radius all around wheel well. Folded over a small edge and welded to the inner well. Plan to cover lower rocker panels and the wheel well opening with some bedliner.
#100
Tires were hitting the body mount really bad up front. Started to plan a body mount chop...................the realized I never took off the wheel spacers from the Tacoma wheels and the 35's. Took them off, clears just fine
Anyone need some spacers and wheels with worn 35;s? They will be in classifieds real soon.
