93-98 T100s All T100 trucks
Jammed Lock
Old Jan 19, 2009 | 09:23 PM
Sloth21's Avatar
Jammed Lock
I have manual Locking doors on my truck. My problem is I can't unlock the driver side door using the key. N E 1 have an idea to whats wrong and how to fix?
Old Jan 20, 2009 | 05:58 AM
aviator's Avatar
I had a similar problem with the pax side door on my 94 once... basically the lubrication had worn off and the linkage had seized up. I pulled the inner door panel, removed some old pine tree needles that were biding around the mechanism {no idea how they got there}, fiddled with it a bit manually to free it up and white lithium spray greased the thing like crazy. since then no issues [touch wood]....
hope this helped
edit: you may also have a problem with the key cylinder it self sometimes they get corroded and the pins seize. if they do not move freely they will not engage the key properly and the cylinder will not turn.
i'd try a lock de-icer spray with a hot key followed by a a good shot of graphite lock lube and see if that frees it up before you pull the door panel.
If you need a new cylinder almost any locksmith shop will be able to recode the replacement to match your existing key for around $20
Old Jan 22, 2009 | 02:39 PM
Sloth21's Avatar
Thanx I will try that
Old Jan 23, 2009 | 11:49 PM
BamZipPow's Avatar
Has it always been this way when you bought the truck? New or used? If used and it's always been this way...are you sure the key going to the door matches the rest of the truck?
Old Jan 25, 2009 | 09:35 PM
Sloth21's Avatar
No this started happening last september.
Old Feb 18, 2009 | 05:08 PM
Sloth21's Avatar
I tried the lock de-icer then put sum lube in there and its still jammed
Old Feb 18, 2009 | 07:36 PM
BamZipPow's Avatar
Here's some insight on how to disassemble/reassemble the lock if yer willing to give it a try... []
You might be able to source some locks at the yard, too...
Old Feb 19, 2009 | 03:10 AM
GSGALLANT's Avatar
A quick shot of PB Blaster in the key cylinder is what I used to free up two seized lock cylinders this past weekend. It worked in approx 5 seconds, and they are now just like new. If it's the linkage that's seized, you'll need to take the door panel off.
ladybugRC
458
Aug 21, 2020 10:41 AM
PNW94Runner
Sep 29, 2015 02:55 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Jason4X4
Sep 17, 2015 08:02 AM
