93-98 T100s All T100 trucks
carrier bearing 96 T100
Old Apr 2, 2011 | 02:16 PM
chili's Avatar
Any advice or knowledge on this subject is appreciated, My carrier bearing for my T100 has to be bad, it is an original part on my 222000 mile pickup, and it is sagging. Something is rattling and knocking in the drive train so I figured I would replace the U joints and bearing. It would have to happen sometime soon anyhow. the bearings I have been looking at all have a note on the order that it excludes four wheel drive. I phoned up Toyota and they said that they are listed differently and have separate part numbers. but with all my looking I cannot find a measurable difference or there is not one listed. I found a new bearing on eBay for 43.66 and Toyota wants 186.71. And I found one for 101.00 so does anyone have any input? my question is: is there a difference between the 2WD and 4WD drive shaft carrier bearings? by the way the part number for the 4WD is 372-30-35120. thanks in advance
chili
Old Apr 2, 2011 | 03:02 PM
DJ99's Avatar
IMHO, go with ebay. I saw it for $44.99 free shipped using part #37230-35120:
http://cgi.ebay.com/ebaymotors/95-02...Q5fAccessories
Old Apr 2, 2011 | 04:03 PM
chili's Avatar
thanks DJ99 did not see that one.
Old Apr 29, 2011 | 06:22 PM
ruggz's Avatar
Just did mine Got it from rock auto for around $75. Just use pb blaster for about a week to loosen up the bolts. Use a box wrench 14mm to get the drive shaft bolts loose you only need to loosen the bolts directly behind the bearing. remove the bolt inside the flange then change the bearing and use lock tight blue during re assembly.
stanz
Oct 30, 2015 10:33 AM
Regency
Sep 24, 2015 07:23 PM
tallsasquatch
Sep 20, 2015 02:48 PM
mat
Sep 17, 2015 11:18 PM
Tcsdef
Sep 7, 2015 11:17 PM
