93-98 T100s All T100 trucks
97 t100 4x4 3.4 liter starting problems
Old Oct 27, 2013 | 06:56 PM
Bodine1969's Avatar
I just replaced the motor in my truck, and when I tryed turning it over my starter just zinged. It was trying to engage because after I tryed cranking the truck I turned the crank and could hear the bendix disengage. So I replaced the starter and battery and still have the same problem. I have checked all the grounds and they seem to be ok. Does anyone have any suggestions? Thank you for your help.
Old Oct 27, 2013 | 07:18 PM
vital22re's Avatar
totally a bro
auto or 5spd? gear ring may be bad.
Old Oct 28, 2013 | 02:49 AM
Bodine1969's Avatar
It's a auto. And the gear ring was in great shape when I put it back together. It's almost like the starter isn't getting enough power.
Old Oct 28, 2013 | 03:17 PM
Bodine1969's Avatar
Ok here is a update of what I did this afternoon. As I said before this is a long block that I just put in. The starter is new and when I turn it over it engages but just spins not turning the motor over. So I pulled the starter and found that the teeth are engaging the flex plate 3/4 of there depth. I thought I may have put the flex plate on backwards but now I know this is not the case. Put it back together and still does the same thing. So I ran a set of jumper cables from the battery ground straight to the starter and still the same thing. Does the starter have to be shimmed etc.??? There weren't any when it came apart. Does anyone have any suggestions?
Old Oct 28, 2013 | 04:49 PM
CJM's Avatar
CJM
Possible you have the wrong starter? I ordered a rebuilt tacoma/4runner starter off ebay and it is smaller than the one on my t100. Thankfully I just swapped the contacts.
Old Oct 29, 2013 | 02:44 AM
Bodine1969's Avatar
I don't think so. I pulled the starter and took it to auto zone where I called myself matching it against the new one. Did I mention my old starter was doing the same thing.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
toy89yota
Jun 24, 2015 01:18 PM
quaale94TRD
3.4 Swaps
Jun 23, 2015 10:27 AM
Edionne13
Jun 21, 2015 11:37 PM
