93-98 T100s All T100 trucks
93 T100 3vze Water Pump
Old Mar 5, 2012 | 12:20 PM
duke4347's Avatar
One last question before i get back to work on it;
Is it better to take the power steering pulley off before going at the crank bolt? And is a puller necessary to get the p/s pulley off?
Thx
Old Mar 6, 2012 | 02:28 AM
rustyf99's Avatar
I took the whole pump off but I was doing the head gaskets. It's only 3 bolts iirc - easier than getting that pulley off.
Old Mar 6, 2012 | 04:27 AM
duke4347's Avatar
I meant the other p/s pulley that is in front of the crank pulley, do i need to take that one off before loosening the crankshaft bolt? I want to make sure i take everything off in the proper order. Thx
Old Mar 6, 2012 | 05:01 AM
rustyf99's Avatar
Yes, sorry. If I recall correctly there are four bolts around the outside of the crank bolt, take that one off and the one behind it is what I bolted the flat stock to for leverage while I "cranked" on the crank bolt with the breaker bar and a 4' iron pipe "extension". My impact didn't fit in that space... :-(
Old Mar 6, 2012 | 05:32 AM
  #25
duke4347's Avatar
Thx Rusty, us newbies need clarification alot. Thx again!!!
Old Mar 11, 2012 | 10:32 AM
  #26
duke4347's Avatar
So i got everything apart except the crankshaft bolt. A friend is coming by tomorrow to help me get it loose....
Problem: i broke/cracked the No. 1 timing belt cover while trying to get crank bolt loose, does anyone know where i can get one online?
Old Mar 11, 2012 | 10:52 AM
  #27
rworegon's Avatar
http://www.toyotapartsales.com
http://www.toyotapartseast.com
https://www.1sttoyotaparts.com/account.html
Old Mar 11, 2012 | 10:53 AM
  #28
duke4347's Avatar
Thanks!
Old Mar 11, 2012 | 05:57 PM
  #29
duke4347's Avatar
So i have everything apart now, ready to assemble, looking for any suggestions/warnings...Thx
Old Apr 5, 2012 | 07:17 AM
  #30
duke4347's Avatar
Hi, i finally got everything installed and back together and its all good! No leaks! No overheat! Only thing is i have a squeal from one of the belts for about 10 seconds upon startup (it squealed for 30-45 seconds for the first start)...fan/ps belt is pretty tight and the alternator one is slightly loose...any guesses on which one would cause this?
Thanks to everyone that helped me on this site, i couldn't have done it without your help. I live in a rural area and had no access to any other help but this site! It was the first 'major' repair i have undertaken. Many, many, many thanks...i love my Toyota Truck! Im so glad to have it running again!
As i get more experience working on my trucks, i will pay back by contributing to this site, thanks again guys!!!!
Old Apr 5, 2012 | 02:30 PM
  #31
BamZipPow's Avatar
Carefully check each belt...the slick one will be the one that's squealing...
Old Apr 5, 2012 | 02:31 PM
  #32
rworegon's Avatar
Good job, duke!
Old Apr 5, 2012 | 03:10 PM
  #33
duke4347's Avatar
Thanks rworegon!!! :-)
Bamzippow: Neither is slick...could that mean the timing belt is squealing? :-(
I cleaned everything with brake cleaner before i put the timing belt on, i sure hope its not that cuz i dont want to get into all that again just yet lol..
When i test drove it, i noticed that if i had the heating fan on the 3rd setting, it squealed from a dead stop....does that say anything? So squealing upon startup and from a dead stop with the fan setting full blast...
Old Apr 5, 2012 | 06:39 PM
  #34
BamZipPow's Avatar
Talking
If yer timing belt is squealing...you've got bigger problems because the timing belt should have teeth...so that can't be it.
Since yer putting a load on the alternator when you put the fan blower on...I would have to guess yer alternator belt is either too loose or it's picked up a shiny spot on it somewhere. How many times has it squealed? Just like tires or anything rubber...if you burn the rubber too many times...it's gonna harden up and shine.
Git a belt tension gauge and tighten the belt to specs...
Old Apr 5, 2012 | 07:23 PM
  #35
duke4347's Avatar
Ok, will do, thx for your input
Old Aug 17, 2012 | 06:59 PM
  #36
TurkeyHearseDriver's Avatar
Crankshaft Pulley Removal
You can get by without a special tool by wrapping a chain around the frame on both sides of the engine. Insert a hi-grade 3/8 bolt through the chain into the pully/harmonic balancer and loosen or tighten, whichever you need. No special tool required.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
jjrbus
Jul 19, 2015 02:06 PM
Snort
Jul 19, 2015 07:03 AM
Jonny246
Jul 12, 2015 04:51 AM
