93-98 T100s All T100 trucks
1996 T100 has a whirring, buzzing at low speed
Old Aug 26, 2012 | 01:13 AM
Sabre2012's Avatar
What the heck ? My 1996 T100 4x4 has a whirring, buzzing from underneath, center of the truck, only when driving at 5-15 mph. And only after 5-7 miles.
Belts, muffler, heat shields, or low trans fluid ?
Where do I start ? Happy trails and thank you...Mike
Old Aug 26, 2012 | 06:43 AM
rworegon's Avatar
Crawl under there and start looking for anything that could cause a vibration. Does anything look out-of-place?
Old Aug 26, 2012 | 11:59 PM
BamZipPow's Avatar
Common area to look at is the heat shield on the crossover pipe. This can be easily fixed by grabbing the heat shield with some pliers and tweaking it.
Old Aug 27, 2012 | 12:51 AM
Zpd426's Avatar
check your front driveshaft also. The noise could be a knuckle going. Check your transfer case that it has fluid. another noise could be your speedo cable wearing out. but that would be infront of you not in the center under the truck.
Old Aug 28, 2012 | 12:11 AM
Sabre2012's Avatar
Thanks guys- Checking tomorrow !
BeMiceElf
Oct 10, 2015 09:40 PM
kyletbert
Jul 17, 2015 11:39 AM
jgwerth
Jul 16, 2015 03:23 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
