General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
What's best way to run wires (for a light bar) through the firewall on an 04 4runner
Old Aug 24, 2009 | 10:43 PM
N736RA's Avatar
Whats the best way to route wires (coming from inside the cabin) through the firewall to the battery (on an 04 4runner)? Is there any reason I shouldn't just run them through the existing plug that the rest of the wires are going through?
-Thanks!
Old Aug 24, 2009 | 10:46 PM
rupert94's Avatar
i put lights on my truck and when i went thru the firewall i ran it nest to the hood pop cablewith a coat hanger
Old Aug 24, 2009 | 11:05 PM
olharleyman's Avatar
-Thanks!
I ran mine that way at first but did not feel comfortable with it just in case of a short some where some time so what I did was drilled a hole big enough to fit the wires through , shrink wrapped them then added a rubber grommet so the wires could not get chafed and short out then ran the wires up to the dash where they hook into the on/off switch.
You will also want to add an in line fuse so they blow the fuse before shorting out the rest of your truck that's the way I did mine and it paid off once already.
Old Aug 25, 2009 | 04:11 PM
DIHOWARD's Avatar
there's another gasket thats behind the glove box. I ran my wires through there up through the A pillar and along the sun roof channel and out through a hole I drilled in the roof.
Old Aug 27, 2009 | 12:24 PM
N736RA's Avatar
Thanks for the input, DIhoward, when you ran the wires through the firewall plug, I'm guessing you had to cut the end off of that little rubber stopper thing to open up the hole?
Old Aug 27, 2009 | 01:02 PM
Tofer's Avatar
Sponsor
where did you get the plug for up top?
gillesdetrail
Nov 19, 2019 12:56 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
voiddweller
19
May 2, 2016 09:10 PM
Gamble_STi
Jun 27, 2015 07:54 PM
ibayne
Jun 26, 2015 06:30 AM
