What's best way to run wires (for a light bar) through the firewall on an 04 4runner
Whats the best way to route wires (coming from inside the cabin) through the firewall to the battery (on an 04 4runner)? Is there any reason I shouldn't just run them through the existing plug that the rest of the wires are going through?
-Thanks! |
i put lights on my truck and when i went thru the firewall i ran it nest to the hood pop cablewith a coat hanger
Originally Posted by N736RA
(Post 51213166)
-Thanks! You will also want to add an in line fuse so they blow the fuse before shorting out the rest of your truck that's the way I did mine and it paid off once already. |
there's another gasket thats behind the glove box. I ran my wires through there up through the A pillar and along the sun roof channel and out through a hole I drilled in the roof.
http://i234.photobucket.com/albums/e...3/DSC04599.jpg http://i234.photobucket.com/albums/e...3/DSC04600.jpg http://i234.photobucket.com/albums/e...3/DSC04603.jpg http://i234.photobucket.com/albums/e...3/DSC04589.jpg http://i234.photobucket.com/albums/e...3/DSC04568.jpg |
Thanks for the input, DIhoward, when you ran the wires through the firewall plug, I'm guessing you had to cut the end off of that little rubber stopper thing to open up the hole?
where did you get the plug for up top?
