General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
**URGENT** No power windows / no dash
Old Nov 15, 2007 | 09:59 PM
raboyto2's Avatar
I was doing some work on the Hilux today, and i was curious to see if i could start the truck on just one battery (truck has dual battery set up) When i tried this, the glow plugs and everything turned on, but when i engaged the starter, there was a "unhealthy" sound. I just figured , "i guess i cant" . I put the ground back on the second battery and continued doing my work. Changed all the diffys/transfer case/tranny fluids, replaced rear shocks, and greased the hole drive line.
When i went to start up the truck, i noticed that NOTHING was coming up on the dash when i turned the key. I could hear the glow plugs working, and the truck started, but no tack, no oil pressure, no lights what so ever. The only light that works is the battery light. I also have to jam it into drive. It does now want to get out of park? Heres a list of what works, and what doesnt.
Does not work:
Power Windows
All dash service lights (glow plug, timing belt etc)
All gauges, except gas gauge
sunroof
Power doors when pressing button on door
Works :
Power Doors when pressing keyless remote.
Tailgate window
headlights
dash back lights (lights up the dash)
hard / soft suspension (light works also)
Vehicle :
1992 Hilux Surf 2lte with dual batteries
I checked all the fuses (foot panel / engine bay) , they are all fine, unless im missing a fuse box somewhere. I couldnt find anything that says "power windows". I dont know what to do because my window is STUCK OPEN! Its suppose to snow in a few days... Is there a way to close the window ?? Like taking the door panel off and "boosting" the window motor or powering the motor yourself? I just REALLY need to close that window, i can live without the dash for a while, but not without a window.
Old Nov 15, 2007 | 11:02 PM
DeathCougar's Avatar
Sounds like you missed a fuse. Sounds like one of the higher amp fuses too. Check for burned/scarred cables, and make sure you are getting full voltage.
Old Nov 16, 2007 | 12:25 AM
02Surf SSR-X 4xSport's Avatar
You may want to check your "10A Guage" &/or "30A Power" fuses on the junction block located at the driver's kick panel.
Old Nov 16, 2007 | 12:26 AM
stormin94's Avatar
Check your relays, and fuses.
Old Nov 16, 2007 | 07:35 AM
raboyto2's Avatar
Thanks for all the help you guys. I have inspected all the fuses, but not the relays. I will also check all the grounds. Il do some electrical "digging". This sucks...
Old Nov 18, 2007 | 12:05 AM
raboyto2's Avatar
Update : 4wd does not work (no light, and does not work mechanically) , also, none of the heater controls work. Everything on the dash lights up, but does not work.
Old Nov 23, 2007 | 04:42 AM
bigt's Avatar
try the power window circuity breaker... mine was a 30 ampo fuse BY the fuse kick pannel to the right
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
