General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Trailer lights wiring help
Old Mar 8, 2006 | 02:54 PM
VA_Yotaman's Avatar
I am trying to repair the trailer lights on my Toyota pickup. I had one of those Hoppie plug and play kits go bad, so I am using the existing wiring. I have the tail lights and turn signals done correctly, but where to you connect the brake lights? I tried splicing into the green and yellow wires (left, right turn) but it just back feeds the turn signals into the brake lights.
Old Mar 8, 2006 | 03:28 PM
Yoda's Avatar
I bought a kit at NAPA. Plugs into each tail light, connect 1 ground and you are done.
If you want to do it yourself, you need to buy a converter for the brake/turns
Old May 28, 2007 | 03:44 PM
Robrt32's Avatar
I got the same problem.. Ive wired a pig tails into fords and chevy without a problem, years ago, But on the toy , i can't seem to make the brake lights work.. What do i have to do? I'm stumped.. I searched and this is the only thread i could find with my problem and i didn't really understand the answer
Old May 28, 2007 | 05:42 PM
4Crawler's Avatar
I have a U-haul 5-wire to 4-wire adapter box in my '85 and it seems to work fine. Tapped into the rear wiring on the driver's side with one wire over to get the right hand turn signal. You'll need the box with blocking diodes to split off the signals properly. Or there are high end converters with relays built in to drive the trailer lights.
Old May 28, 2007 | 06:22 PM
frodin1's Avatar
The plug-n-play replacements are actually really cheap. I guess the Toyota ones are around $100.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Johntom240
7
Jul 13, 2015 12:18 AM
toyota32
Jul 6, 2015 05:42 PM
