General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
stereo clicking
Old May 23, 2006 | 03:41 PM
uberhahn's Avatar
stereo clicking
I have an RPM specific "click" when listening to the radio. Not a relay, but the sound is RPM dependent. Not sure if the radio is picking up the ignition, injectors...something else?
Could this be a symptom of a bad ground? The HU is a Pioneer. The noise isn't there with a CD, which makes sense.
Any ideas?
Old May 24, 2006 | 08:31 AM
EnolaGaia's Avatar
Seems to me if it were a bad ground you'd be getting the clicking all the time. When you say it's not there in 'non-CD' mode - you mean with the AM/FM, right? If so, I'd start by looking for something exposed or making contact in the antenna circuit....
Old May 25, 2006 | 04:34 AM
NC-B17A's Avatar
Check the ground on your eng & batt. You are hearing the sparkplugs fire. Have you changed sparkplug wires recently & what kind are they?
Do you have a volt/ohm meter? If so you can also check the antenna ground.
Where is the ground on you radio? If you used the ground wire in the harness that could be a problem in a Toyota the radio needs to be grounded to the chassis.
Old Jun 10, 2006 | 10:01 PM
boogyman's Avatar
On my pioneer HU, I can hear the engine wind up through the stereo when I put the stereo into aux input mode, and my aux device is off. If I were hearing it during radio or CD play like you were, I would install a power (or ground) line filter in the stereo wiring. I think you can pick them up cheap at Radio Shack.
Davebarbier
Nov 3, 2015 03:28 PM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
