General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Starter problem after flat battery
Old Oct 5, 2014 | 02:13 PM
fumusfumus's Avatar
Batteries went nearly flat (left something on). Just about started for 2 days, then came to fix it today.
Cold weather so not enough juice in battery to turn it fast enough even twice before it completely flattened it.
Tried jump leads, but whirring / click noise like the bendix drive in the starter is stuck between teeth. But not whirring fast enough to sound like a usual bendix drive issue, so perhaps its something else.
Any ideas for getting it going again please?
Old Oct 5, 2014 | 02:27 PM
vital22re's Avatar
totally a bro
A new battery. Sounds like an amperage issue. Battery is most likely damaged internally.
Old Oct 5, 2014 | 02:52 PM
fumusfumus's Avatar
Thanks. But would that happen when its connected to another car's battery to jump start it?
Old Oct 5, 2014 | 03:26 PM
vital22re's Avatar
totally a bro
even with a jump start if the dead battery has nothing or isn't able to hold any charge it will not have enough to start.
Old Oct 5, 2014 | 11:42 PM
wyoming9's Avatar
Red face
Just how cold was it??
A discharged battery will freeze.
If your trying to jump start two dead batteries it will take some time to get them to the point where it will crank over.
As the system voltages will equal out so the boost vehicle alternator is putting out all it can.
Depending on the boost vehicle output it could take a good 30 minutes or longer.
Then one also needs to take the size of the cables into the equation as well
Old Oct 6, 2014 | 10:00 PM
fumusfumus's Avatar
Thanks everyone. After your comments I used another jump car with a better connection, revved the jump car hard and the Surf started easily. Drove around for 30 mins and it put some charge back in. Will get the batteries etc checked now.
nick9455649
Sep 11, 2015 05:10 PM
ZONAYODA
Jul 13, 2015 07:17 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
Nickdigg
Jul 7, 2015 06:04 AM
colinmil
Jul 6, 2015 04:03 PM
