General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Reverse lights for trailer
Old Sep 2, 2004 | 01:51 PM
akprodr@yahoo.com's Avatar
I'm slowly working on wiring my '00 Tacoma for pulling a trailer. The thing that's got me stumped now is the reverse lights. I know I don't really need 'em but the trailer is wired for it so I figure I might as well...
I ran a wire from the 7 pin connector at the hitch to the engine compartment. But I can't figure out where to hook it up. Is there a fuse for the reverse lights? Does this wire end up in the engine compartment at all or does it end under the dash?
Any help appreciated...
Andy
Old Sep 2, 2004 | 02:01 PM
Flamedx4's Avatar
Why didn't you just run the wire from the connector up to the nearest reverse light?
Old Sep 2, 2004 | 03:50 PM
Well now, that would make too much sense wouldn't it? What I had in mind was doing it 'the right way'--finding a good place to hook it in the engine compartment. Hooking it up to the reverse light would be cheating...
Probably what I'll end up doing though...
Old Sep 2, 2004 | 04:32 PM
User 051420's Avatar
Not cheating....why run needless wires?
Old Sep 2, 2004 | 04:36 PM
superjoe83's Avatar
you may want to keep that wire that you put in the engine compartment for a power wire for a relay, i would recommend using a relay which is triggered off of your backup lights, that way you don't overload your factory harness
Old Sep 2, 2004 | 04:47 PM
SoCal4Running's Avatar
Definatly use a relay, I think the trailers two extra lights and 20' of wire will blow a fuse out.
Old Sep 2, 2004 | 05:07 PM
Actually, I was going to put the relay in the trailer itself and run the lights off of the trailer battery.
I wasn't exactly sure what I would be needing so I ran 4 wires: a brake control wire (10ga), two wires (12ga each) for 12 v power to the trailer for battery charging and frig, and a wire for the reverse lights.
I did the brake controller first since that was fairly mandatory. I've finally assembled all the pieces I need for the 12 volt run. I was hoping to do the reverse lights at the same time.
I'm planning to put the circuit breaker and relay for the 12 volt inbetween the battery and the wheel well. I'll have to remove the battery to do that
so I have to find an adequate amount of time. If someone has an idea for a better place to put it, lemme know...
Old Feb 10, 2008 | 10:46 AM
Solutions by Design's Avatar
Possible solution to all 12v trailer light problems.
I have designed a rather special relay that isolates the vehicle lights and switches on the trailer lights. This is especialy useful for fog and reversing lights where they are not wanted on the towing vehicle as long as the trailer lights are working (no bulb failured). So its all pritty safe and fit and forget stuff and it is entirely passsive so no wire runs to the front of the vehicle. Let me now if you want one. Two would be required if the lights you are switching are left and right individually fused.
AkitaDog
Sep 1, 2015 08:05 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
rchavis
Jul 27, 2015 07:41 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
