General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
relay question
Old Oct 10, 2021 | 12:55 PM
Darylzane's Avatar
relay question
As far as I'm aware this is on my truck a starter relay or an AC relay, it has a corresponding relay in the cab though where it routes powered night heater and AC that doesn't exist. Completely wired up no AC no compressor nothing. Starter relay? And whats the purpose of this wiring?
Oh the bottom left, yeah that little missing chunk, I wouldn't worry bout that little guy.
Old Oct 10, 2021 | 06:42 PM
BigBluePile's Avatar
The starter relay would be out in the engine bay, passenger side.
What vehicle? I'm assuming it is the standard back to the future type...
Old Oct 10, 2021 | 10:46 PM
RAD4Runner's Avatar
Could you please have a more understandable, clearer description of your problem or what you are trying to do?
Old Oct 10, 2021 | 11:53 PM
Darylzane's Avatar
oh right
Context would help, I'm doing a complete harness rewire. Also I can not only learn how to be able to fix my 85 pickup at any given time but also because I'm going to be building a camper on the back. Among a few other things, turns out I didn't need to do the rewire at all, but I didnt know till it was out. like I said I'm new to this and I found out they were almost no grounds done properly.
But that's the context and that's just a relay that I believe is for the mostly for the ignition system
Old Oct 11, 2021 | 07:48 AM
Sounds like you have a lot to do.
Old Oct 12, 2021 | 02:19 AM
Darylzane's Avatar
I've been at this for months, there's two crappy parts, one I didnt need to rewire. The voltage drops were all bad grounds I bet. But I can't be certain. Too much time in electrical it's best to take the battery out. At least as far as safety with electricity. Second, I had near zero experience under the hood. On the bright side. I have parts and do-hickies up the wazoo, likely enough to wire another truck. Ahhh having practically zero memory, it's so expensive.
Larry H
Aug 21, 2018 11:27 AM
Tommy T.
Feb 20, 2016 07:08 AM
mengquis
Aug 4, 2014 08:01 AM
cheappc
Mar 22, 2013 10:58 PM
Dean
Sep 17, 2002 07:38 AM
