Sponsored by: CARiD
Part question starter relay
Old Aug 20, 2018 | 04:17 PM
Larry H's Avatar
I have a bad starter relay #28300-35010 , on a 1988 toyota 3.0v6. I have checked with toyota part has been discontinued. Do I have anyother options as far as rewiring to get truck to crank? I have checked Rock auto the one they show looks nothing like the one I have. One is listed on ebay but looks rough. Thanks
Old Aug 21, 2018 | 12:33 AM
wyoming9's Avatar
Red face
It is a simple 12VDC 2 pins for the coil 2 pins for the contacts
It does not have to look like the one you have just work the same
I use Napa for non dealer parts
The Relay you need is # ECH AR355 it has a list price of under $20.00
You have tested the relay and it does not work ?? Physical damage?
Not that swapping relays does not fix the problem
Old Aug 21, 2018 | 11:27 AM
Larry H's Avatar
Thanks for information. I just wasn't sure if relay listed on Rock Auto was the same. The relay I have has a 4 wires soldered to it, with twist connector which goes to 4 more wires. Took bad relay apart contacts have damage.
CCDave
Jun 11, 2018 05:44 PM
85TRD4runner
Nov 19, 2016 02:42 PM
angrybob
Mar 24, 2012 11:57 PM
Harold Of The Rocks
May 3, 2009 10:27 PM
helopilot
Aug 25, 2006 01:46 PM
