General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
quick question about drl
Old Dec 30, 2008 | 06:43 AM
schmooot's Avatar
90 4runner. Does the drl system just light up the headlights or does it light everything (markers, dash, headlights)? And is there a write-up to disable them? If there is I can look it up myself...unless someone has the link handy
Old Dec 30, 2008 | 07:08 AM
scuba's Avatar
I dont know the link, but if you look in here...http://personal.utulsa.edu/~nathan-buchanan/93fsm/
find the lighting section, it will show you where the drl box is, I believe all you have to do is un hook a plug.
Old Dec 30, 2008 | 09:22 AM
4Crawler's Avatar
See below:
- http://www.4crawler.com/4x4/CheapTri...ghts.shtml#DRL
Old Dec 30, 2008 | 11:15 AM
schmooot's Avatar
Thanks I found the schematic and it helps somewhat. It appears that under drl operation the headlights are on 85% and the taillights are illuminated. The problem with my truck is every light is on 100%.....and setting the parking brake before starting the truck does not disable the system. I believe this is why I can't get my remote start to go into ready mode (manual)..I disabled the drl by cutting the black/orange wire at the relay but now I'm curious as to why it was doing that. Any ideas?
Old Dec 31, 2008 | 06:36 AM
schmooot's Avatar
well I got the remote start working. It was a combination of an intermittant hood switch and I didn't have the secondary ignition hooked up so that is solved. Still wondering if something has been modified or broken to make all the lights operate under drl
Old Jan 25, 2009 | 08:22 PM
wolfpack10's Avatar
Push switch
Know where the least expensive place I can buy a push switch to turn DRLs on/off like in Corey's write-up? Please don't tell me to search cause I have.
Old Jan 25, 2009 | 08:28 PM
scuba's Avatar
first place I would check for an OEM switch like that would be a dealership, the part number is right above the picture of the switch...
jasonty
41
Dec 23, 2018 01:00 PM
thefishguy77
Aug 9, 2015 04:15 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
icentropy
Jul 14, 2015 10:23 AM
