General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
PIAA wiring ton Contura Switch
Old Jan 29, 2012 | 08:35 AM
stanz's Avatar
PIAA wiring to Contura Switch
I thought I'd surely find my answer on here or google with a quick search but I haven't had any luck
I want to wire up my new set of PIAA 520s to a Carling Contura rocker switch. There are three wires going into the factory PIAA switch: red, white, black.
My question is simple: which is is which?
-I assume black is ground
-Which is then the power feed and which is the power out?
Thanks!
Mike
Old Jan 29, 2012 | 09:06 AM
justin_4runner's Avatar
well easy way is hook up the power wire to the battery and see what one has power at the harness where u want to go to ur switch, but in most cases red power, white to item u are powering and black neg.
Old Jan 29, 2012 | 10:43 AM
wyoming9's Avatar
Red face
Break out your Meter
Most switches are labeled
You most often have the light wire if the switch is lit with the lights and the other 2 wires just break or close a hot wire.
if this is a double throw switch it breaks or closes two circuits
Old Feb 5, 2012 | 07:54 PM
stanz's Avatar
I got it all wired up and working great this weekend. I only have one question remaining, which is a silly one... I was expecting that the on position for the Contura switch would be with the lower part of the switch depressed (this position: \ ).
Instead, it's this pattern:
-On: /
-Off: \
Everything works great and I swear I wired it correctly per the instructions and which wires are which. I'm just wondering if this is how these switches should work, or if I got two wires switched.
Thanks in advance!
Old Feb 5, 2012 | 08:23 PM
nv4runner's Avatar
Could you flip the switch around to work how you want it to?
Old Feb 5, 2012 | 09:13 PM
stanz's Avatar
No, it's this one:
http://www.otrattw.com/proddetail.ph...J66B-AYC4S-17V
Old Feb 5, 2012 | 09:54 PM
stanz's Avatar
Looks like I found my answer online. I did wire the switch correctly. For contura's on is / and off is \. Case closed.
stock87yota
Jul 31, 2015 10:08 AM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
Johntom240
7
Jul 13, 2015 12:18 AM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
