General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
One of those "What is this connector" questions...
Old Sep 4, 2013 | 04:32 PM
Dauphinc's Avatar
'86 22RE. It looked like rats had gotten to the wires to this connector, it's in bad shape. It plugs into the lower intake manifold, towards the front (front meaning near cylinder intake port #1)..can someone tell me A: what is the function of this, and B: where would I find another connector?
Attached Thumbnails One of those "What is this connector" questions...-photo-2-2-.jpg
Old Sep 4, 2013 | 04:36 PM
Dauphinc's Avatar
Here is another pic of it.
Attached Thumbnails One of those "What is this connector" questions...-photo.jpg
Old Sep 4, 2013 | 05:05 PM
Philbert's Avatar
It's green right?
Coolant temp sender plug. To the right of the intake as you face the motor. It's important to have for proper ECU/emissions during engine warmup. There is a brown plug coming off the same loom, which connects to teh sender next to it.
Old Sep 4, 2013 | 05:08 PM
Philbert's Avatar
my image doesn't seem to work...try this link:
http://i286.photobucket.com/albums/l...zky/img150.jpg
Old Sep 4, 2013 | 05:23 PM
Dauphinc's Avatar
It's not the coolant unit, I've already replaced that one because it was rotten literally. LOL. If you are standing on the pass side, reach under the upper manifold, heading towards the engine, it's in there. It's attached to the lower manifold its not any of the sensors you can see from the front.
Old Sep 4, 2013 | 05:35 PM
Philbert's Avatar
Is it blue? I couldn't tell on my screen. If blue, it plugs into the back of the idle air control valve. Comes off the wiring harness that is sandwiched between upper and lower manifolds.
Old Sep 4, 2013 | 06:13 PM
Dauphinc's Avatar
It looks like it maybe used to be blue..it's a real dark hunter green color. I'll check on iac valve connectors real quick and see.
Old Sep 4, 2013 | 07:18 PM
Philbert's Avatar
can you share some photos of those areas of your engine so we can get an idea if you're missing anythin?
Old Sep 5, 2013 | 05:11 AM
Dauphinc's Avatar
Yeah man ill take some when I get home a little later.
Old Sep 5, 2013 | 08:45 AM
Dauphinc's Avatar
Ok man, it's the IAC connector. I took it off and there it was. I got some female spades, put them into the connectors inside of the iac, then epoxied them in. Good to go!!
stanz
Oct 30, 2015 10:33 AM
Centmo
12
Jun 22, 2009 08:33 AM
95yoda
Jun 3, 2008 06:02 AM
1994_4Runner
Nov 3, 2004 09:16 PM
AndroT100
Apr 22, 2004 07:51 AM
