O2 Wiring
Originally Posted by Yoda
Don't know the wiring, but why are you tapping into the rear O2?
I don't believe you get accurate AF ratio readings after the cat has cleaned it
I have some diagrams. What engine you have?
my engine is 2TR-FE
Originally Posted by dz
in that case, you'd be looking for the front O2, as the rear O2 is behind the first cat. (just confirmed this by looking at mine)
in his defense, he did say he would make an 02 simulator to keep the ECU happy for the sensor he didn't need. But, if your going to make a simulator, and keep the engine thinking its reading its own exhasut and appropiate 02 levels, why not just let it actually read its own 02 levels?
The rear O2 sensor is there to keep an eye on the cat (like DZ pointed out). It's a small function, but it's "required by law". As such, the ECU will throw a code if it doesn't see it there, or if it's malfunctioning. And, as such, you'll fail emissions since your check engine light is on.
ahhh... wait a minute. I screwed up.
Originally Posted by Yota_Kid
i am installing a wideband O2 which will be used to feed accurate AFR readings to a seperate fuel and timing unit.
Originally Posted by midiwall
Right... And the simulator is usually used in the front sensor so that you have control over faking the ECU into open loop for tuning.
So, are you looking to run a MegaSquirt II or somesuch and completely do away with the stock ECU?
so far, its just been a few replies as to what the O2's do. i know that already, was looking for the wiring diagram. i'll probably just buy the service manual and run some voltage tests on the leads so i can build a small sim (voltage regulator and heater load).
plus, with the second O2 sensor still installed, it'll still let you know if your cat is crapping out.
http://www.google.com/search?hl=en&l...am&btnG=Search
http://www.ecanfix.com/~mdhamilton/o2sensor.html
with a sim i dont need the O2 sensor in the exhaust, thats what a sim does.
This is the reason I'm kinda' busting on you. I had a feeling that you may not quite be sure about how a sensor works and what the ECU expects to see.
Many of the simulators are more correctly described as "conditioners". Down that line, these can help:
http://o2simulator.com/
http://splitsec.com/products/conditioner.htm
The reason to run a conditioner is so that you can make the emissions folks happy in terms of the OBD II interface being happy. The ECU will still see the stock O2 sensor in the loop, but it'll get out of the way when you want it to.
Now, if you're really looking for a true replacement, you'll have to do a bit more circuit work. Check here:
http://www.bobblick.com/techref/proj.../o2sensor.html
The final circuit he describes is here:
http://www.bobblick.com/techref/proj...sim/o2sim.html
i dont need the O2 to tell me this. my emmissions will meet or exceed CA emissions standards, even after i install my turbo.
At the end of all this, I guess I'm still curious as to why you don't just stuff the rear sensor in the pipe, let the ECU see it and be done. You're running a stock ECU, the rear sensor isn't affecting performance, and having it there will save you a ton of time in building and debugging a real simulator.
None the less, you have the info to take whichever route you choose.
Google...
I don't want to beat a dead horse here, but are you thinking that an O2 simulator is just about maintaining a constant voltage? It's not, and the ECU will recognize a constant CV as trouble and throw a code.
Whichever route you chose, you will have to BE SURE that the ECU thinks that there's a sensor out there. If there's not, it'll set a flag (but maybe not throw a code) and when you head for emissions testing, and they plug into the ODB II side of the ECU, OBD II will report the issue and they'll fail you.
as for why i dont want the rear O2, is because the cat might not be there while i run turbo on a daily basis.
i dont want to argue my case, but the links you quoted are not specific to a 2006 Tacoma, and the other link to making a O2 Sim circuit is for adjusting the AFR (sim for front O2). i'm only sim'ing the rear O2.
The bottom line is that you can't just toss a 0.8v regulated voltage in there and expect it to work.
I'm trying to help... But feel free to ignore it and do what you think is best.
ToyoToler
Aug 8, 2015 08:43 AM
