General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Need Help Removing Wires From 1999 V6 Coil Pack Connectors
Old Oct 7, 2014 | 05:32 PM
TRD8's Avatar
I am looking for some help identifying the correct tool and how to use it to remove the wires from my 1999 V6 coil packs connectors shown below. Any help would be greatly appreciated.
Thanks in advance!
Old Oct 10, 2014 | 10:57 PM
wyoming9's Avatar
Red face
The correct tool is make your own I most often file a small flat screw driver to fit.
Since there are different sizes I have a few .
Then you take apart the connector in the usual manor.
It is in the Toyota Electrical Wiring Diagrams which you should have.
Old Oct 11, 2014 | 02:31 AM
TRD8's Avatar
Thanks for the reply. But could you explan what you mean by, "Then you take apart the connector in the usual manor" ? Does the connector come apart and then the wires pull out, or the the wires just get pushed out?
Thanks,
Again
Old Oct 11, 2014 | 06:28 AM
rworegon's Avatar
This or this or this thread from another forum may help you out.
Old Oct 11, 2014 | 02:48 PM
TRD8's Avatar
Thanks guys, the info gets me closer to where I need to be.
I picked the connectors today and it appears the white part of the connector in the second photo is a lock.
I'll post some additional photos of the new "unlocked" later.
Thanks again
Old Nov 12, 2014 | 03:44 PM
TRD8's Avatar
The part number for the connector I needed is: 90980-11246 The connectors were about $3.00 each
The second photo shows the white part of the connector in the “unlocked” position. I have heard this part of the connector described as the secondary boundary. I used a small pick with a 90 deg. bend to pull the white piece out halfway and then used a small flat jewlers screwdriver to unlock the wire and pull it out the backside of the connector. Installing the wires into the new connector was easy enough as they snapped into place, and then pushing the white plastic part back flush finished the installation.
Old Nov 12, 2014 | 11:19 PM
wyoming9's Avatar
Red face
Just what happened to your plugs you needed to change them??
Old Nov 13, 2014 | 03:55 AM
TRD8's Avatar
The locking device part of the connector that keeps it locked onto the coil pack broke.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
some drunk guy
Aug 3, 2021 06:09 PM
mct75
Aug 22, 2016 01:24 PM
the_supernerd
Oct 1, 2015 09:20 PM
PBRaddict#1
Sep 14, 2015 04:18 PM
