General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Need help hooking up switch for power inverter
Old Jan 9, 2006 | 07:45 AM
Joyota's Avatar
I got a 750W Vector power inverter for Christmas, and am going to hardwire it in. I would like to put a switch on the dash for powering it up whenever I want. My problem is that it could possibly draw up to 125 amps (1500W Surge). That eliminates using a relay, as most aren't rated that high.
Now I don't know anything about them, but would a starter solenoid work for this? A starter solenoid operates on pretty much the same principle as a relay, right (low-power activates high-power)? Could a garden tractor, motorcycle or snowmobile starter solenoid be used?
Old Jan 9, 2006 | 08:04 AM
Corey's Avatar
Co-Founder/Administrator
Take a look in the Tech sectoin for the solenoid I used for the Ramsey Wireless Remote I put on my winch.
The solenoid is made by Warn, and it works great.
The link I have to the solenoid though is bad, Warn revamped their site shortly after I wrote the article.
Old Jan 10, 2006 | 06:22 AM
fourwd1's Avatar
relay = solenoid, electronics term vs automotive term
If you really plan to use the inverter a lot, you will need a continuous duty solenoid, which a starter solenoid isn't.
An inexpensive cont duty solenoid is a Borg Warner S-55.
Old Jan 10, 2006 | 07:47 AM
Joyota's Avatar
Cool, thanks guys. I appreciate the help!
80Truck
Oct 12, 2025 07:25 PM
montanatruck
Feb 26, 2017 07:07 AM
94yotaky
Jul 23, 2015 07:50 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
Johntom240
7
Jul 13, 2015 12:18 AM
