General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Low tail lights
Old May 6, 2017 | 10:39 AM
nottoshabi's Avatar
5 Year Member
Low tail lights
When I sit at the light with the headlights on the truck makes a weird noise and the charge light flickers on and off. Also my tail lights are very dim and the turn signals you can barely see, if I turn the headlights off then the tail lights and turn signals work correctly during the day you can see the tail lights and turn signals work without a problem it's only when the headlights are on.
Does this mean that my alternator it's on his way out and will this also fix the very dim tail lights and turn signals?
Old May 6, 2017 | 12:21 PM
flg8r22's Avatar
If your unable to test the alternator yourself, have a parts store give it a go. Also check your belt for wear, cracks, proper tension etc. If you find you need a new alternator and have the ability, Get the rebuild parts from the dealer and do it yourself, or if you need to purchase a new one, make sure its the proper amps and not a piece of trash sent here by China.
Old May 6, 2017 | 04:50 PM
nottoshabi's Avatar
5 Year Member
Rock auto sell's rebuilt ones for $15. I will get mine checked first before purchase.
Old May 6, 2017 | 04:56 PM
flg8r22's Avatar
That seems like a really low price
Old May 7, 2017 | 12:47 AM
wyoming9's Avatar
Red face
It might be almost any thing in the charging system .
Loose Alternator belt
Corroded connections
broken or loose battery terminals
Time to breakout the Meter and get some real numbers
Then just what your working on might be good to know
Old May 24, 2017 | 05:38 PM
nottoshabi's Avatar
5 Year Member
Got a new battery, that fixed the problem. The are nice and bright now.
Old May 24, 2017 | 08:11 PM
RAD4Runner's Avatar
Good to know. Thanks for keeping us posted.
