General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Light Bars and CB's
Old Dec 18, 2011 | 11:17 AM
93' MAC's Avatar
Light Bars and CB's
I'm looking to hook up my Light Bar w/ lights and my CB as well. But I don't want wires all over the place and looking like crap, so I was thinking of making a custom center console that has a built in slot for the CB to sit in and a hole for my toggle switch for the Light bar. Any Ideas? I have a 1993 Toyota Pickup Extended cab.
Old Dec 18, 2011 | 11:38 AM
bob200587's Avatar
If it's one of the smaller CB's a lot of people put them in the ash tray slot.
I think you should be able to run the lighting wires through the inside of the bar and have them come out at the bottom, and in through the back of the cab. Might take some drilling and a couple small rubber grommets.
Old Dec 18, 2011 | 11:46 AM
93' MAC's Avatar
I tried to fit it in the slot in the dash and its just a little bit to big but I might be able to come up with something. I eventually want to install a cd player to replace the stock cassette player. I could put the wires down through the light bar I was just trying to avoid drilling holes because I live in Maine and we get a lot of snow and rain.
Old Dec 18, 2011 | 12:04 PM
bob200587's Avatar
Well, you're either going to have to run the wires on the outside of the light bar or the inside. Outside is ugly, inside requires drilling.
Old Dec 18, 2011 | 12:13 PM
93' MAC's Avatar
Where on the cab would I drill? up through the bottom?
Old Dec 18, 2011 | 01:00 PM
toyota4x4907's Avatar
There are water drain holes already in the floor. Pull up the carpet a little at the corners and there will be a 1"-2" hole with a rubber cap. Pull the cap up a little and wire it in through there. Or make a hole in the cap. Thats what I did on my '93 when I had lights on the roll bar.
Old Dec 18, 2011 | 03:09 PM
93Xtra-Cab's Avatar
There isn't too much room inside these little trucks to be mounting accessories, unfortunately. You could always trim the dash pieces to fit. I've also seen them mounted on the glove box door, under the steering wheel on the steering column, mounted on the passenger side of the shifters, etc. One I haven't seen but have thought of for when I mount mine is in the front of the drivers seat, in between your legs with the controls facing up. It really all depends on how anal you are about how things look.
As for the switch, there are little tabs in the dash you can pry out gently with a screwdriver. All you have to do is trim the plastic wall along the back of the tab and drill the hole.
Old Dec 19, 2011 | 12:45 PM
peow130's Avatar
Wait until you have a CD player, then mount the CB under the radio..
As for the wires, use a hot soldering iron or screwdriver and put a few holes in the rubber grommets, then run your wires through that.
Blamalam
Mar 12, 2022 07:34 AM
4.34runner88
Aug 11, 2018 10:44 AM
Sep 4, 2015 09:27 AM
AkitaDog
Sep 1, 2015 08:05 AM
DrZero
18
Jul 24, 2015 11:31 PM
