General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Help? Diagnostic port...
Old Nov 28, 2015 | 08:53 PM
BrownRecluse's Avatar
So I bought a great 4x4 1988 Toyota pickup with a replaced 22re, but some of the Wiring I've seen in a couple places is questionable like, for instance a bent up paper clip in the diagnostic port... Should I document the ports it's bridging and replace it after I remove it and something goes wrong? I don't know what to do..
Old Nov 28, 2015 | 09:15 PM
dropzone's Avatar
Fossilized
sounds like someone left a jumper in there
Old Nov 29, 2015 | 12:13 AM
wyoming9's Avatar
Red face
Bypassed all the fuel pump safeties to sell the truck???
Could be the switch in the AFM or the Circuit Opening Relay or wiring has failed.
Old Nov 29, 2015 | 05:27 AM
Terrys87's Avatar
Sounds like they by passed the fuel pump which is the Fp/+B
How to get Check Engine Codes. Applies to 87 and up.
Fp +B Fuel Pump Test for 87 and newer. Use a paper clip for better results.
Old Nov 29, 2015 | 03:24 PM
It's in T and E
Old Nov 29, 2015 | 06:30 PM
Terrys87's Avatar
The T and E is used to set the Timing and is also how you get your Check Engine Light codes. I can not see any reason that they would of left it in trying to bypass some issue. If it had been in the Fp and +B I would say that they were basically energizing the fuel pump full time. Since it is T/E you should be able to remove without any worries.
Old Dec 11, 2015 | 05:30 PM
So I took it out and it's now a tad bit clunky when warm 400 -600 rpm
presto30
Engine Swaps
Dec 10, 2015 12:01 PM
RoadRage
Oct 9, 2015 07:43 PM
Brodetski
Sep 30, 2015 11:50 PM
Bowman5115
Sep 29, 2015 08:55 PM
Bowman5115
Sep 19, 2015 03:04 PM
