General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlights are broken
Old May 29, 2004 | 08:10 PM
wvuviv30's Avatar
Alrighty... I went with a set of 80/100-Watt bulbs and I got the upgraded wiring harness also for my 94 4Runner. Well the wire harness fits into all the sockets. The wire harness worked all right.
This is the Kit I bought: http://cgi.ebay.com/ebaymotors/ws/eB...category=33710
But the other day I hit the high beams and NOTHING, I have low beams (with aftermarket harness). I undo the harness and stick some other bulbs into the original sockets; they light up high and low. So my question is what should I do? Can someone explain to me why isn't working? All the relays are GOOD.
Has anyone re-wired the headlights using the stock Relay and Fuse Panel?? Or is it safe to run an 80/100 bulb on the stock harness?
I NEED HELP FAST!!!!
Old May 30, 2004 | 03:20 PM
slimtim's Avatar
is it possible that with the old bulbs and new harness, a short might have fried the highbeam fillament? from what i understand is u replaced the harness and bulbs and now ur bulb highbeams dont work, and when u replaced the bulbs they work? or is it possible the new harness is blown or has a short?
Old Jan 10, 2007 | 01:56 PM
88yotasr5runner's Avatar
yep sounds like burnt bulbs to me!!
Old Jan 10, 2007 | 02:15 PM
Elton's Avatar
is that harness a switched ground set up ?
Old Jan 10, 2007 | 03:10 PM
4Crawler's Avatar
What sort of wiring harness is this? Have you checked out the relays (that I assume are in the harness) and the fuses/fusible-links in the harness?
- http://www.4crawler.com/4x4/CheapTri...shtml#TechInfo
And x2 on checking the bulbs, you can often see if one of the 2 filaments inside the bulb is burned out.
Old Jan 10, 2007 | 07:40 PM
L33T35T 4Runner's Avatar
Well you changed two variables at once, so it's hard to tell which one is wrong.
plug the harness back into the bulbs that worked with high and low, go from there
ladybugRC
458
Aug 21, 2020 10:41 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
Brodetski
Sep 30, 2015 11:50 PM
