General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Fuel Pump Problem
Old Oct 5, 2007 | 09:45 AM
jonboy99's Avatar
Fuel Pump Problem
I have an 88 pickup with a 22RE. My problem is that the fuel pump hasn't been working so I ran a direct line from the battery to the fuel pump wire in the test box under the hood. But the fuel pump still will not turn on. What I would like to know is if that means that the fuel pump is bad or is there something else that would keep it from turning on.
Old Oct 5, 2007 | 09:53 AM
OSU4Runner's Avatar
Check the ground for the fuel pump and make sure you do have good power going to the pump. Check with a multimeter. If you ground and power is good to the pump, then I would say it was bad.
Old Oct 5, 2007 | 11:26 AM
4Crawler's Avatar
Try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Could be your Air Flow Meter fuel pump contact is inoperative.
Old Oct 5, 2007 | 05:07 PM
jonboy99's Avatar
I checked the voltage to the line going to the fuel pump and it was only getting like 6.7.
Old Oct 5, 2007 | 05:18 PM
OSU4Runner's Avatar
You should be getting 12V, I only see one resistor in that schematic and its inside the circuit relay. You might have a voltage drop somewhere in the line. Did you check this with the ignition on? Also, did you check the ground at the pump? and fuses too!
Old Oct 5, 2007 | 05:29 PM
4Crawler's Avatar
Could be dirty contacts inside the relay or a bad wire between the relay and the pump.
Old Oct 5, 2007 | 05:32 PM
jonboy99's Avatar
I had somebody turn the ignition over while i checked the voltage and yes I have checked the fuses but i haven't replaced the relay yet
Old Oct 5, 2007 | 05:36 PM
jonboy99's Avatar
where is the resistor located at that is on the same line as the pump
Old Oct 5, 2007 | 05:38 PM
OSU4Runner's Avatar
From the schematic, its looks like its inside the circuit opening relay.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
