General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Electrical- lights
Old Oct 29, 2006 | 02:01 PM
edenweiss's Avatar
Electrical- lights
Electrical- lights
I have a 1989 Pick up 4-cyl 4WD 5-spd. I have electrical problems with the lighting system. I have headlights but no running lights. Brake lights work and so do hazard and turn signals. Just no running lights? Any help would be great I am new I hope this is the right place to post this question. Many thanks in advance-
Eden
Old Oct 29, 2006 | 02:04 PM
Elton's Avatar
welcome to yotatech.... have you check the fuses the may looks fine but they can be bad
Old Oct 29, 2006 | 02:09 PM
edenweiss's Avatar
Electrical- lights
Thanks Elton for the quick response! I pulled them and they looked fine. I will pull them all again at the driver side left foot kick panel. I will check them for continuty with my meter. I also purchased a new headlight switch $55 from the parts store under their direction. I have taken the steering wheel off to get at the switch and the wiring harness. After carefully taking everything apart (especiallt the pins that are socketed into the wiring harness) and installing the new switch I am at the place I started. Everything except the running/parking lights-
many thanks again,
Eden
Old Oct 29, 2006 | 02:13 PM
Elton's Avatar
do the dash lights still work ? did it just start doing it have you installed any thing ?
Old Oct 29, 2006 | 02:20 PM
edenweiss's Avatar
Electrical- lights
NO DASH lights either sorry. I have installed several things. Cig lighter for 12v power and a brake light kit for a trailer. The brake light kit is the no splice no fuss kind where the kactory brake light pig tails coupl into this new harness and the new harness provides trailer leads. The trailer light kit was 2 years ago at least though? Cig lighter was last December when I got Sirius.
Thanks,
Eden
Old Oct 29, 2006 | 04:45 PM
4Crawler's Avatar
Disconnect the last things you added and see if anything changes. Also, check the grounds for the running lights, front and back and then pull the bulbs and check the sockets and bulbs for damage.
Old Oct 29, 2006 | 10:18 PM
tribb333's Avatar
Sounds just like what i experienced tonight, gonna try to check things out tomorrow, will come back to post if i can help.
My problem has to do with blowing fuses repeatedly. The tail light fuse blows after like 5 secs of having the lights on. Guessing it's a short, so we'll see.
Old Oct 29, 2006 | 10:28 PM
Elton's Avatar
check to see if the tail light wireing is in good shape
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
