General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
electical issues
Old Dec 3, 2007 | 06:05 PM
pete4runner's Avatar
Question electical issues
hello out there.new guy to the site.ihave a 1996 4runner that is giving me grief.
the problem started when i shut the truck off and pull the key the daytime running lights,abs pump was staying on.also the oil pessure light came on.i have tested the ignition switch and it seems fine.i then started pulling fuses one at a time.alas when i pull the alt-s 7.5 amp fuse in the engine bay fusebox everything shuts off.i should also mention that the issue was intermittent at first and now all the time.any help would be greatly appreciated.thanks in advance
Old Dec 4, 2007 | 11:02 AM
4Crawler's Avatar
Might check the relays, perhaps one of them is sticking on. Since you have it isolated to a fuse, check the relays that are on the circuit that fuse is for and see if any are still on (pull the relay and see if things shut off). Relays can do this if the contacts become pitted and you get enough buildup on one side of the contact to span the gap between the contacts or if the contacts actually become welded together.
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
rjtrials
Aug 6, 2015 07:25 PM
nonstop
Jul 24, 2015 06:29 PM
