General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Electic Fan Switch option
Old 11-22-2010, 06:35 PM
Outsane's Avatar
This is for those of us who want to put in an electric fan and want an automatic switch..
I bought a hayden fan controller but it broke, an I have been using a switch for long time. Forgot to turn it on a couple of times, once crawling through a canyon.
So here is my solution, the OEM fan switch for a Honda bolts right in..
I used a fan switch from a 1990 Honda CRX, screws directly into the coolant drain plug on the drivers side of the motor to right of the exhaust manifold.
It completes a connection at 195 deg and doesn't turn back off for a while.
http://www.summitracing.com/parts/SMP-TS84/
The "Standard" brand name TS84 has a shorter nub on the end, I think I broke the stock one because it was too long. These can be found for much cheaper, I got mine for $15 it was just the first link.
I have it set up now with three relays in parallel, and a second set of relays on a switch which I will keep until I know the system works perfectly. Later I may use the switch to turn the fan off for those deep water crossings I never do.
The following 2 users liked this post by Outsane:
muddpigg (11-22-2010), ohp676 (11-22-2010)
Old 11-22-2010, 06:52 PM
ohp676's Avatar
Great Idea. THanks
Old 11-22-2010, 07:21 PM
muddpigg's Avatar
Nice. Will remember this.
Old 12-11-2010, 09:41 AM
aviator's Avatar
Sounds like a good idea... why 3 relays parallel? + 3 more on switch?
I understand why u have the switch as a back-up system... just curious why the multiple relay set up...
Old 12-14-2010, 09:31 AM
Outsane's Avatar
forgot about this post...
The three 40 amp relays in parallel is to cover the high load on start up, two sets were set up that way as I went through several options. I'll probably run the AC on the low fan setting and the thermo switch to the high fan setting.
I am plan on making the fan automatically turn on with the AC (that needs a recharge).
and I may leave the switch in the cab not sure.
Not going to make a switch to turn the fan off, not many water crossings of that depth here in San Diego, and I can always just pull the connector apart on the fan.
Old 12-14-2010, 10:38 AM
aviator's Avatar
I get it now.... though why not just use a larger cap. single relay? It would be more reliable because there where less components to fail...
the usual practice is for the thermo switch to activate the low setting and the AC switch to activate the high setting. This is because the engine is going to call for cooling more often than the AC (generally) and a "constant" high setting would draw too much power and possibly over cool the engine. Also remember the AC condenser coil is in front of the rad and the fan has to pull the air through both the high setting is more efficient for this.
As for the auto on with the aC that's easy... just tap the fan relay set inline with the AC power line. Check the polarities though remember Toyota likes to use a switched ground for things not a switched "hot" like NA mfgs. {I don't know if this is the case with the AC switch I don't have the schematic open in front of me just now.
Old 12-15-2010, 12:14 PM
Outsane's Avatar
I didn't use a larger capacity relay, cause I have not found any for a reasonable price, and I had a bunch of 40amp relays
wiring should be fine for the AC, super easy with blade connectors if I remember right.
If OEM usually goes High for AC and low for Engine, I will do the same.
Old 12-16-2010, 09:31 AM
aviator's Avatar
Being in SanD you may want to add a switch so you can turn on the high fan without turning on the AC. I think the OEM can do that for cases where the low fan cannot keep up like in very hot conditions with low airflow like traffic jams and so on...
Just a thought... of course in those conditions you'd have the ac on anyway so...
Old 12-16-2010, 09:55 AM
Outsane's Avatar
yeah, I would like to make a set up that would just start low for engine or AC, then kick to high if both are on..
have to see if I can find a simple route for that
Old 02-27-2012, 11:49 AM
csout's Avatar
Outsane, you have a picture for this Honda OEM fan switch ? 3VZE or 22re?
Old 02-27-2012, 01:49 PM
Outsane's Avatar
here is one I found online..
22re
Old 02-28-2012, 12:06 PM
csout's Avatar
Thanks Outsane. I should have been more clear about what I was asking for. How about a pic of where you installed the Electric Fan Switch.
I see you did this for the 22re. What was the thread? M12?
Anyone find a thread location to use on the 3VZE?
Old 02-28-2012, 12:16 PM
Crazy Hakachukai's Avatar
Be careful using relays in parallel like that.
What will probably eventually happen is one relay will stop working first, leaving the other 2 over loaded.
Then eventually relay #2 will die faster (because of higher load)
Then relay #3 will die an even faster super overloaded death!
How many amps does that fan pull on start up?
Old 02-28-2012, 12:38 PM
Outsane's Avatar
Correct relay made for continous use would be a better option, I still need to source one..
there is a lot of info here..https://www.yotatech.com/forums/f116...61/index7.html
I am currently using a totally different set up now..
https://www.yotatech.com/forums/f131...roller-244645/
no pics yet it was raining yesterday
the1998sr5
15
07-14-2020 08:35 PM
coryc85
09-09-2015 06:24 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
1996Taco
07-20-2015 12:02 AM
msane99
07-17-2015 10:13 AM
Quick Reply: Electic Fan Switch option
