General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Differences between 96 t100 harness and 97?
Old Jan 2, 2017 | 08:51 AM
shoes138's Avatar
Just wanted to know if there are any big difference between a 96 to 97 harness. The reason i ask is im currently in the process of swapping over a 96 5vz and looking to supercharge it. Found out that the 96 ecu does recognize the boost and heard that the 97 will work fine just may give off a check engine light.
Old Jan 4, 2017 | 11:37 PM
wyoming9's Avatar
Red face
It just depends what you call big differences
T100 I am sure the T100 curse will be involved in some way.
If you change every thing so the engine is now a T100 engine it will be easier
This is something you need to sit down look at the EWD`s from both years your going to need to get the4th ECM plug and wire this more then likely.
I am guessing the ECM plugs will be different between the years
I don`t have the T100 EWD`s to double check .
I T100 was enough I still have nightmares !!
Old Feb 20, 2020 | 11:16 AM
KingGelbin's Avatar
Disappointed to not see any replies to this since I'm also having the same problem with my 1996 T-100.
I must have joined to wrong Toyota message forum?
Thord
Aug 8, 2020 05:51 PM
Henno
Pennsylvania
Nov 3, 2017 12:22 PM
glee08
Engine Swaps
Oct 28, 2014 09:34 AM
