General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Cruise control and turn signals
Old Nov 20, 2009 | 03:40 AM
Speedy_McTall's Avatar
Hi,
Is the cruise control supposed to disengage if you use your turn signal? I am sorting out an electrical butcher job by the P.O. of my truck and wanted to know if this is normal behavior or not. Seems a bit odd to me.
Thanks!
Old Nov 20, 2009 | 05:48 AM
4Crawler's Avatar
Nope, but likely some connection between the two circuits. My '85 factory cruise sometimes does that as well. I suspect mine might be due to a trailer light wiring box in back, might try disconnecting things like that if you have them and see if anything changes. Could also be due to a power or ground issue, cab ground is a screw into the sheet metal behind the driver's side kick panel.
ghostmoney
Jan 28, 2018 11:42 AM
Shoua
13
May 22, 2016 05:19 AM
shisha1999
Sep 21, 2015 08:22 PM
jake_v
Jul 22, 2015 03:17 PM
rushw
Jul 18, 2015 01:46 PM
