General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Can I wire a relay this way??
Old Feb 28, 2007 | 09:56 AM
deserttoy84's Avatar
Ok my paint skills are horrible but i think it gets the point across. what im thinking is run the main positive and the trigger positive directly to the battery and then run the ground wire through the fire wall to a switch then to a ground to trip the relay. I want to do it this way so i have a ground wire running through the firewall and stuff and not live wires. will this hurt the relay in any way?
Old Feb 28, 2007 | 10:25 AM
wjwerdna's Avatar
should be okay, only need to run one (fused) wire to relay, and a jumper to trigger positive, but your wire going to switch will still be "live" between the switch and the relay either way
Old Feb 28, 2007 | 10:39 AM
Yoda's Avatar
Will work fine. That is the way horn relays are wired
Old Feb 28, 2007 | 12:24 PM
ill prob fuse the main power feed form the battery with a 30 amp fuse because its a 30 amp relay(or should i run a 25?). the relay will be right next to the battery so im not too worried about shorts. can wait to get my hid spot light all wired up now.
okamikai
Apr 30, 2018 10:19 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
jackiebrownia
Jul 20, 2015 09:02 AM
msane99
Jul 17, 2015 10:13 AM
colinmil
Jul 6, 2015 04:03 PM
