General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Blinker Flasher Questions
Old Apr 24, 2007 | 10:48 PM
Doozy's Avatar
I have a 1998 Tacoma and my Blinkers Don't Work. Left, Right, Hazard lights all don't work. The arrows on the cluster don't light up, not fast, not slow, not steady, not at all. I press the emergency light switch and still, nothing happens at all.
I've tried to find the flasher or the relay and can't seem to find either. It is possible they are completely missing! Any advice on what the problem could be, and where to find the problem would be greatly appreciated.
Thank You
Old Apr 24, 2007 | 10:52 PM
Tofer's Avatar
Sponsor
i read Blinker fluid question....... sorry...
did you check the fuse?!
Old Apr 25, 2007 | 06:27 AM
4Crawler's Avatar
A Factory Service Manual would show the location of the flasher relay.
- http://www.4crawler.com/4x4/FSM.shtml
In my '85 it is located behind the kick panel in the driver's side footwell.
Old Apr 25, 2007 | 06:31 AM
eric-the-red's Avatar
On 4Runners the flasher relay is on the back of the fuse panel below the driver side dash. Check there.
Old Apr 25, 2007 | 09:15 AM
surf4runner's Avatar
i did too that'd be a doozy of a requst
Old Apr 25, 2007 | 10:11 PM
Doozy's Avatar
Found It
It was missing! I found one and plugged it in. Everything works perfect. It is located on the back of the fuse panel. Thanks
ghostmoney
Jan 28, 2018 11:42 AM
mussy01
Dec 13, 2016 08:20 PM
Shoua
13
May 22, 2016 05:19 AM
PNWrider
Oct 30, 2015 08:14 AM
jimkoz26
Aug 5, 2015 03:15 PM
