General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Airbag light is on - code is 31 -T100
Old Sep 16, 2019 | 12:13 PM
The Lorax's Avatar
1996 t100
2.7 4cyl 5sp
My truck has the airbag light always on, I checked the code and it is 31 - Center Air Bag Sensor Assembly Malfunction.
I little research suggests that replacing the airbag ECU (Control Module). Has anyone had this issue and fixed it without replacing the control module?
Where is the Control Module located on the 96 T100?
I've found several used ones online (junkyards), but want to make sure I get the right one. Does it matter if the unit is coming from a truck that has a different engine or other variables like auto vs manual etc.?
Is this a pretty easy (plug and play) replacement?
Old Sep 18, 2019 | 10:25 AM
old87yota's Avatar
Do you have the Factory Repair Manual for your T100?
I have one for a 2002 4Runner which is similar electronics wise, but may not be exactly the same.
While I almost never suggest just replacing a control module (in this case, the Center Airbag Sensor Assembly), this code is pretty limited to supply power, ground and the Center Airbag Sensor Assembly itself as to what the problems could be.
Below is the test procedure for the 2002 4Runner, which looks similar to the procedure described in a few posts I read for T100s. If I were you, I would want to confirm where the pins IG2 and ACC are located on your T100 before proceeding with the following test!
Thord
Aug 8, 2020 05:51 PM
Sawyer
May 17, 2015 07:36 AM
NateT100
Nov 19, 2009 12:32 PM
Praufet
Sep 15, 2006 12:00 AM
