94 engine 22re in 90 model pickup wiring bad
I have a 90 model truck and a 94 model engine the body wiring harness sucks. pretty much the oxygen sensor wire what all do I have to do to get this truck running right it is running way too rich
okay i need to know what harness i need a 94 or a 90 and what computer some ppl say i need the 90 it was the same truck what computer and where will i get these items i cant find them somebody please call me so I dont spend a fortune i know nothing 606 424 5088
Is the O2 sensor on the 90 on the exhaust manifold or is it on the catalytic converter? My 86 has a 3 wire ( on the cat) but the later models have the 4 wire (on the exh.man). If the harness is original to the truck then I'd venture to say that you need the O2 and comp from the 90. I had a similar situation when I replaced the engine from a carb'ed truck with an EFI Celica engine, I just left the "extra" O2 sensor unhooked! Make sense?
it is on the exhaust manifold I dont think the people that did the swap b4 I did the rebuild knew what they were going. I think (not sure) the 90 model had has a fuel injected engine. But, the wiring harness is from somethhing 95+... Do you know where i can get a wiring harness that would match this truck up with the engine so I can finally drive it and what about the computer do I need a 94 model computer??
voiddweller
19
May 2, 2016 09:10 PM
saphirekosmos
Jun 22, 2015 10:26 AM
