General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
'85 Clock, Lighter, and Radio - Something fried?
Old Aug 17, 2010 | 05:22 PM
abrunner's Avatar
Hi all,
I have a new-to-me '85 4Runner. While driving a few weeks back I plugged my GPS's power cord into the cigarette lighter and the lighter, clock, and radio all died simultaneously.
I figured it was a fuse at the time. I checked all fuses, though, and none are blown (although a couple had corrosion in the box). I have an after market stereo and speakers installed by the previous owner, so I pulled everything out to follow the power wires, but nothing is jumping out at me.
In searching online I haven't found any recurring themes, so I assume this is not a common problem. Can anyone confirm that?
I've looked at wiring diagrams in multiple manuals. To be honest I haven't dealt much with electrical problems, but I looked up some how-to's on reading the diagrams. I guess at this point I need to buy a meter and start digging in - maybe a relay?
Old Aug 17, 2010 | 05:38 PM
4Crawler's Avatar
Look at the fusible link at the back of the lighter socket. Mine went out about 9 years ago and it looked like a blob of solder that had melted. I just re-soldered the wire back to the plug, eliminating the link. Later I re-powered the lighter with a fused wire straight to the battery.
Old Aug 17, 2010 | 05:43 PM
abrunner's Avatar
Would this cause the entire circuit to short rendering the radio and clock inoperable as well?
Thanks in advance for the advice. Your website is really helpful. I used it to troubleshoot a rear window issue and to verify I was checking the correct fuse for this problem.
Old Aug 17, 2010 | 05:47 PM
4Crawler's Avatar
Don't recall if that happened to mine or not. Might also check/replace the CIG fuse if you did not already do so:
- http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
Sometimes a fuse can look OK, but still be blown.
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Chicken12
Oct 14, 2015 03:54 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
