General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
81 4x4 electrical problem
Old Nov 14, 2007 | 06:06 PM
lenwood's Avatar
Exclamation 81 4x4 electrical problem
i have headlights,turnsignals,flashers,radio...........no heater fan,no reverse lights,no gauges or warning lights,trucks electric choke not working,high idles constantly. alternator is working fine. i'm stumped......any suggestions?
Old Nov 14, 2007 | 06:23 PM
rowdy235's Avatar
fuses all good? Fusible Links? Relays? Check the choke per service manual instructions.
Old Nov 15, 2007 | 02:51 AM
4banginRunner's Avatar
either the relays are bad or the headlights, taillights, and flashers are in 2 relays mounted together with 1 plug under the drivers side dash, check if thats connected
Old Nov 15, 2007 | 07:39 AM
dropzone's Avatar
Fossilized
OK, I tried scanning the wiring diagram out of my '81 Factory service manual. you will have to print them and piece them together as I could only do 8x11 at a time, I hope this helps you out :
Sorry it is kind of a random order and some of it may have been got off, but just got home from a long a$$ shift and I feel like crap...
here are the links from photobucket if that is easier:
http://i119.photobucket.com/albums/o...wiring/019.jpg
http://i119.photobucket.com/albums/o...wiring/020.jpg
http://i119.photobucket.com/albums/o...wiring/021.jpg
http://i119.photobucket.com/albums/o...wiring/022.jpg
http://i119.photobucket.com/albums/o...wiring/023.jpg
http://i119.photobucket.com/albums/o...wiring/024.jpg
http://i119.photobucket.com/albums/o...wiring/025.jpg
If somebody knows how/has the programs to put this in PDF format let me know I can email the files to you....
Old Nov 15, 2007 | 10:48 AM
lenwood's Avatar
thanks guys, replacing the voltage reg today to see if it helps. if not diggin into my bently manual. i think it may be a short or ground problem if the vr doesnt fix it
Old Nov 18, 2007 | 08:24 PM
Island_Yota's Avatar
Mine did the same thing, It was working perfect until I changed the terminals(and yes I hooked up the battery correctly) I think I killed the 16g Fusable links I put in some how. Maybe just a bad connection.. then I again ive got loose wires everywhere .
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
AaronM
Jul 8, 2015 07:15 PM
