1988 Rear Window, Need Help
Hi,
I've got a 1988 4runner and I can't get the rear window to work for the life in me.
The other windows work fine. The wire diagram I'm looking at shows a power window relay I can't find where that is located on the truck. The switches on the window regulator seem to check out, the switch on the right side latch seems to check out, both the up and down switch and the window lock seems to check out too. I just can't seem to figure out what’s wrong. The window motor works too I can manually hook power to it and it goes up and down. Does anyone have any suggestions?
Thanks,
Jake
The other windows work fine. The wire diagram I'm looking at shows a power window relay I can't find where that is located on the truck. The switches on the window regulator seem to check out, the switch on the right side latch seems to check out, both the up and down switch and the window lock seems to check out too. I just can't seem to figure out what’s wrong. The window motor works too I can manually hook power to it and it goes up and down. Does anyone have any suggestions?Thanks,
Jake
Jun 1, 2021 01:51 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
