General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1986 4runner hardwiring
Old Mar 12, 2012 | 04:19 PM
Dan2e's Avatar
Hi I just purchased a 1986 4runner thats got some wiring issues....the running lights have been hardwired...there is no radio or speakers....and now to the issue NO DASHLIGHTS anyone know what wire it would be behind my dash panel that i could hardwire them in so i can turn them on with the running lights...having to use my cell phone to check my speed sucks any help would be appreciated thanks.
Old Mar 12, 2012 | 09:16 PM
4Crawler's Avatar
You might want to check what is left of the factory radio wiring. Could be those old wires are not properly insulated and are shorting out. That is tied into the dash lights, so would be a good place to start. Make sure each wire is separate and then wrapped in electrical tape or heat shrink so that the bare end can't touch anything conductive.
Otherwise, download a copy of the factory service manual (FSM) wiring diagram and start digging.
Old Mar 12, 2012 | 10:01 PM
Dan2e's Avatar
the factory stereo harness is still in the truck so I guess it's digging for me. Any ideas where I could find a free fsm download?
Old Mar 12, 2012 | 10:05 PM
4Crawler's Avatar
Try the big red button at the top of the forum, has the letters "Search" on it.
Or try here:
- http://www.4x4wire.com/forums/showfl...=0#Post1065861
or here for some other ideas:
- http://www.4crawler.com/4x4/FSM.shtml
Old Mar 12, 2012 | 10:08 PM
Dan2e's Avatar
Lol yeah probably should've thought of that just got off work not thinking straight...thanks for the help I'll get on it in the am
Old Mar 13, 2012 | 04:33 PM
Dan2e's Avatar
Ok so got it wired in but have to pull the fuse to turn it off cuz it won't turn off with the switch any clues what I may have done wrong :-(
Old Mar 13, 2012 | 04:43 PM
BMcEL's Avatar
Not without knowing exactly how you wired it.
Old Mar 13, 2012 | 04:46 PM
Dan2e's Avatar
It's wired to a switch that my running lights are also wired into...they turn off with the switch however but the dash lights stay on even tho the switch is off
Old Mar 14, 2012 | 06:24 AM
4Crawler's Avatar
The dash back lights typically get their power from the tail light relay and fuse and are grounded via the dimmer rheostat. So something is probably messed up with that circuit.
Old Mar 21, 2012 | 06:28 PM
meganzhang's Avatar
I'm going to hardwire the charger on it so I don't have to run the wire to the 12v plug down by my shifter.
Jun 1, 2021 01:51 PM
nanhodges2733
May 29, 2020 03:28 PM
mskalmus
May 28, 2017 07:51 AM
raiderhawks00
Jul 8, 2015 06:23 PM
