General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
03 camry starter relay
Old Apr 12, 2007 | 04:55 PM
toyaholic's Avatar
my mom drove her camry to work today and on break it wouldn't start. i went and checked it out and the battery tested fine, the fuses were fine and when i got in the car and turned the key to accessory and tried the lights the radio would turn off and on. the sunroof buttons worked backwards and the dash lights were all wacked out. later i turned the key to try and start it and i noticed a buzz noise in the fuse block. it was the starter relay, so i decided that was probably the problem, but would that cause all the other electrical problems if it was bad.
Old Apr 12, 2007 | 07:13 PM
toyaholic's Avatar
tested the relay and its fine. i t must not be getting 12v. the search continues.
Old Apr 12, 2007 | 08:44 PM
4Crawler's Avatar
Could be a similar wiring issue as in the earlier vehicles:
http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Basically the starter relay is powered from the ignition switch as is the power it switches.
Old Apr 13, 2007 | 01:28 PM
toyaholic's Avatar
bad battery. didn't know that a battery could be bad and have 12v. wasn't giving enough current. i used my booster pack and the car fired right up. dooohhh!!!!!
ladybugRC
458
Aug 21, 2020 10:41 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
