Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
Viper Alarm remote case replacement
Old Jan 3, 2011 | 06:30 PM
waskillywabbit's Avatar
My new to me 99 ext cab Tacoma has a Viper alarm on it, two button variety, nothing fancy, but the key ring attachment point on the top of the remote case (plastic loop) is busted on both remote cases. I looked on Ebay and found some replacement cases. You think my local place that sells Viper would have any replacment cases and save me some shipping.
I need to find a manual as to how this thing works as I'd like it to beep when I arm/disarm so I know it's done something when I click the button. It's got a remote start feature too.
Alright, back to the Orange Bowl as halftime is almost over.
:wabbit2:
Old Jan 3, 2011 | 06:37 PM
BigBluePile's Avatar
It had a snake in the cab for an alarm? How the heck does it start the truck?!
Old Jan 7, 2011 | 08:38 PM
drpdmazda's Avatar
:wabbit2:
depending on how old the unit is, your local shop may not have a case anymore. i havent seen a viper case in probably 5 years at my place.
you should be able to find a manual on viper ( dei electronics ) website. the model of the alarm should be on the top of the brain.
you said it doesnt make any noise when you lock and unlock, is the led a solid light or blinking? if its solid its in valet mode, which typically wont allow the remote start to work, as well as mutes the sound. basically shuts everything down except for door lock functions. if the light is solid red, you can try one of two methods:
1) find the "valet" button, it should be a small black push button. turn the key to the ON position and hold the button in until the light turns off.
2) if you cant find the valet button or that doesnt work, open the door, press button 1, press button 2, press button 1. it should pop out of valet.
lastly, once the alarm is out of valet, if that is the case. try holding buttons 1 and 2 down at the same time for a few seconds. the parking lights should flash and truck should start if all is well.
good luck, hope some of this helps
Jason
Old Jan 7, 2011 | 08:44 PM
Elton's Avatar
pics of the remote ? might be able to figure out what model it is
Old Jan 10, 2011 | 01:54 PM
Mauzer's Avatar
Jason
^^This, when I purchased my 4Runner the stealership had no idea that it had an alarm with remote start. I got the model # of the brain under the dash and with that I figured out everything else I needed by going on DEI's website. I ordered new remotes and programmed them myself...now I have a full functioned alarm with remote start for "free"
Old Jan 10, 2011 | 02:01 PM
DeathCougar's Avatar
How about just cutting the stupid alarm out of there? I did that to my 4Runner and never looked back. Stock wiring is so much cleaner anyways.
I had nothing but problems with the alarm/remote start on my truck, and it cost me a lot trying to buy new remotes. They would work a short while and break again. Completely pointless.
Old Jan 10, 2011 | 02:17 PM
Mauzer's Avatar
"Don't you put that evil on me Ricky Bobby"
Mine have been working fine for over a year now
Old Jan 10, 2011 | 05:34 PM
drpdmazda's Avatar
sounds like s bad install to me. if installed properly you should have no problems with an aftermarket alarm/remote start. i have one on all 3 of my vehicles and have not had any issues with any of them. you have to be careful when you just go "cutting them out" cut the wrong wires, or dont reconnect certain ones and you can open up one big can of worms.
Old Jan 10, 2011 | 05:53 PM
scuba's Avatar
Take it to your local best buy. They can modify the settings of the alarm and sell you a new remote.
Old Jan 10, 2011 | 05:57 PM
Guts of remote were good. Works flawlessly. Found 2 new cases on EBay for under $20 shipped.
Even has remote start for those cold days.
:wabbit2:
TURBOrunnerNM
Jul 22, 2015 11:01 AM
A2theK
Jul 12, 2015 10:46 AM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
